  • Guests: 51
Cardboard secondary former?
flannelhead
Thu Apr 10 2008, 12:28PM Print
Any opinions or experience on using round cardboard containers as secondary formers? I know that it's slightly conductive and there would be heating problems but... Has anybody ever tried?
quicksilver
Thu Apr 10 2008, 02:35PM
I remember from hobby rocketry that there are different "cardboard" tubes. Some are spiral wound, others are parallel wound (a simple role of material continually glued together). The Parallel wound tube being much stronger and denser. That density may play a role.
I've been thinking about this also. I've heard that PVC is very "lossy" as opposed to other polymer material. However there are alternatives at low cost at hardware stores but the spiral wound cardboard tubes exist in such abundance in the sizes I would want to use.
Thu Apr 10 2008, 02:43PM
Cardboard is fine.
Just be careful about any cardboard with "writing" on it as this may be conductive, as well as "black" cardboard as it may be conductive. But regular brown cardboard is fine. Just coat prior with shellac or similar and wind.
I use large Cardboard sonotubes all the time.
Marko
Thu Apr 10 2008, 03:43PM
Actually, cardboard is more temperature stable than common plastics like PVC, PE or acrylic, and if you dip it in epoxy resin it can also be very mechanically rigid.
What I think of as biggest problem is that you can never get as smooth surface with it like with plastics, which can be troubling if you are attempting to wind really thin (<0.15mm) wire.
Dr. Drone
Thu Apr 10 2008, 08:05PM
shades
lpfthings
Sat Apr 12 2008, 11:03AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Doesn't varnishing the cardboard cause it to absorb the moisture from the varnish, making it semi-conducting.
Avi
Sat Apr 12 2008, 01:27PM
spark wrote ...
All mine are, but they are only very low power coils.
Hrothgar
Fri Apr 18 2008, 01:58AM
Hrothgar Registered Member #1180 Joined: Mon Dec 17 2007, 12:26AM
yeah, why not? I've used nothing but carboard for my secondaries, granted the first one died (but that was due to racing arcs, not card board. Also I've never had any issues with my secondaries heating up. I also never bothered varnishing it before I wound my coil onto it. The only real draw back hat iI've found is that the tubes will warp if you do a real tight wind on it.
