  • Guests: 62
self inductance and inductive reactance
Hrothgar
Wed Apr 09 2008, 11:35PM Print
Hrothgar Registered Member #1180 Joined: Mon Dec 17 2007, 12:26AM
So self inductance is where a the coils own field interacts with its own coils which causes distortions in the mag field. Inductive reactance is when the eddy currents inside a coil produce a current in the opposite direction of current flow? Do I have this right?
Thu Apr 10 2008, 10:19AM
They are two words for the same thing, except inductance is in henries and reactance is in ohms.
Hrothgar
Thu Apr 10 2008, 08:06PM
text books should be standardized, thanks
Antonio
Sun Apr 13 2008, 01:50AM
Reactance is NOT the same thing as inductance. Inductance is the ratio between induced voltage and ratio of variation of current. Self-inductance, or just inductance, if in the same coil, mutual inductance if in two coils. Reactance is the ratio between voltage and current amplitudes, for sinusoidal signals at steady state.
