  • Guests: 33
Fet driver chip alternatives.
Ken M.
Wed Apr 09 2008, 12:57AM Print
Hey Folks,
More or less this is a question, I realize that in most cases for a SSTC we use UCC37322/21 and they work extremely well, but last time I ordered Different drivers I ordered UCC27423's... Heres the Datasheet Link2 , I realize the pin out is different, Digikey keeps rejecting my Debit card so I'm just seeing if you guys think this chip would work to replace the Ucc37321 Link2 , so long as I change the pins connections on the board.
Wed Apr 09 2008, 02:39AM
you can order the UCC3732x from TI directly as free samples.
Linas
Wed Apr 09 2008, 04:11AM
i believe my mosfet GDT driver is better than any UCC, my sstc GDT use just 5 turns, and works without heating,but wave form aren't good, (maybe big mosfet capacity, one mosfet is 6nF ;( )
74HC14_UCC3732X_mosfet_GDT
1207714307 1143 FT43083 Draiveris
Dr. H.
Wed Apr 09 2008, 05:33AM
I don't fully agree with Linas. The descrete driver might be good for high currents and driving big loads (at relatively low frequency), but it suffers from added delay and shotrough at high frequences.
hvguy
Wed Apr 09 2008, 10:32AM
hvguy Registered Member #289 Joined: Mon Mar 06 2006, 10:45AM
IMO the best driver on the market is the IXDD430, with the IXDD414 a close 2nd. I use this in just about everything I build. They are avalible in a TO220 package which makes them perfect for high load aplications (BIG FETs/IGBTs). I use the IXDD430s to drive CM600's at 200khz with ease.
GeordieBoy
Wed Apr 09 2008, 10:36AM
TC4421 and TC4422 are good for most applications where MOSFETs/IGBTs are being driven through GDTs. In this case peak current is normally limited to less than the driver's maximum by leakage inductance and damping resistance anyway.
-Richie,
