  • Guests: 66
Zener Diode G-s Limit
Ken M.
Mon Apr 07 2008, 10:42PM Print
Hey folks,
With the recent repetitive failure of mosfets on my SSTC I added some Zeners (back-to-Back) and put the Mur860's back in, But I can only get the coil to arc when I charge teh 470uF filter cap for the power section, then disconect the wall plug and turn on the driver circuit, which obviously only causes a power on spike and discharges the filter cap.
So for the actual question with Zener diode protection on the G-S What is a value for Zener diodes to be placed there 30V or Can I use 20V since the Max G-s'V I believe for the fets I have is 25V max.
Tue Apr 08 2008, 12:13AM
Depends on your gate drive.
If you're gate drive is driving 15V to the gate, then i'd use 15V zeners. If its 20V, then i'd adjust accordingly.
You want the diodes to clamp, but not to clamp all the time otherwise you'll blow them out.
Zeners are typically used to protect against overshoots, but as long as the overshoot isn't exceeding maximum voltage on the gate, you should be okay.
You can also reduce overshoot by increasing gate R to critically damp it a bit more. (leakage inductance working with gate capacitance)
