  • Guests: 55
RFI-filter for SGTC
Lakeowner
Wed Apr 02 2008, 05:24PM Print
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
I have designed and built partially my (first) SGTC. I faced the filtering problem and have taken a look at commercial line filters at RS and few other stores:
This 10A filter costs quite much for my budget. If I don't get such device from junkyard, I have considered could I build it myself. Is it possible to build it without weeks of work and with small budget? And if it is, is there any guideline? I have tried to use Google, but I obviously know the keywords :). My TC may be powered by 6 MOTs. There will also be huge ballast on primary side. I use SRSG.
northern_lightning
Wed Apr 02 2008, 07:40PM
northern_lightning Registered Member #1348 Joined: Sun Feb 24 2008, 01:48AM
i agree. i'd like to find some schematics for a quality line filter. but in the meantime, rainylk sells some reasonably inexpensive filters.
FireBird
Wed Apr 02 2008, 08:25PM
FireBird Registered Member #1104 Joined: Tue Nov 06 2007, 07:38PM
I would like to know how to make one too because I am debating if it would be easier and cheaper to make it yourself or just buy a cheep one like the eBay line filter.
Coronafix
Sun Apr 13 2008, 08:33AM
I found this e-book on the subject for anyone interested.
Link2,M1
Lakeowner
Sun Apr 13 2008, 09:52AM
Thanks Goldsphere. I think I'll buy one filter from ebay :)
MOT_man
Mon Apr 14 2008, 04:51AM
If you contact the RFI distrubutors - some can be had for free. I just ordered a 240V 60A RFI --as a sample and they sent it free!!
FREE FREE FREE --- just ask!
cjk2
Thu Apr 17 2008, 12:08AM
Electronics goldmine usually has 10a filters for about $10, also, some computer power supplies contain modules rated for 10a. You may be able to find an old computer PSU that has exactly what you need.
Something like this?
Coronafix
Thu Apr 17 2008, 02:36AM
cjk2 wrote ...
Would this be the older types of PSU? How would you ascertain the rating? Would it be in a seperate
case or part of the circuit board?
cjk2
Thu Apr 17 2008, 10:18PM
Computer power supplies almost always have filters. most of the time they are on the board, but i have seen separate power input modules with the IBM style power connectors too. they are almost always rated at 10a. Look for the older AT style power supplies. If you can find a module this way, you could always take a smps with an integrated filter, and simply rebuild the filter on another board.
Coronafix
Thu Apr 17 2008, 11:54PM
Thanks Chris, I am looking into this because I had a 2.2kVA variable transformer that shorted internally after running my coils through it a lot. I am not sure if this was caused by RF, perhaps unlikely, or to running power through at full tilt constantly. I don't use a variac anymore even though I have another little one I am saving for solid state stuff.
I will check out some supplies as suggested. Thanks.
