  • Guests: 51
NST's in parallel
Mon Mar 31 2008, 02:24AM Print
Registered Member #1415 Joined:
My tesla coil currently make 30 inch sparks with a 12kv 30ma NST. What would happen if I bought another transformer the same as mine and wired it in parallel? When I say "what would happen" I mean spark length
Spedy
Mon Mar 31 2008, 03:21AM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
If you just paralleled them, I;m pretty sure it would just increase current available, not voltage.
Mon Mar 31 2008, 04:01AM
I realize that the voltage would stay the same, but does a larger amount of current passing through the primary coil induce more current into the secondary, thus causing a longer spark?
Ultra7
Mon Mar 31 2008, 04:12AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
You'll gain some length and they will be brighter.
You will gain some 14 inches with the higher current.
Teslamap says at 12/30 you should have at least 36" sparks.
With the 12/60 you should have at least 42" sparks.
Just be sure you phase them properly if you decide to parallel them.
Also, keep your runs under 5 minutes to avoid damage to your NST's if you parallel them.
MOT_man
Mon Mar 31 2008, 04:20AM
I have had some strange performance problems with a new NST placed parallel with my 12 kV 120mA 1.44 kW transformer. This one is a power factor corrected NST 12kV 60mA - when I run it off of the same circuit I can hear the transformer fighting with the gap of my tesla coil - yet when I run the transformer off of a separate circuit everything works fine - again its hook in parallel. I'm guessing its a phasing issue. Odd - never tried using power factor corrected NSTs before...
Mon Mar 31 2008, 04:30AM
how do you phase them properly
Ultra7
Mon Mar 31 2008, 05:06AM
SteveC wrote ...
Read this entire article, it has everything.
How to get NST's for almost free, how to crack them, how to parallel them. . .
Remember that paralleling them will probably kill them in extended runs.
Although I've yet to kill one (touches wood) by paralleling, I still try to keep my runs below 5 minutes.
My Variac starts to buzz at around 4 minutes, and my ARSG gets red hot, so I start my shutdown at about 4:30 into the run.
Mon Mar 31 2008, 12:58PM
If you just add another NST in parallel, you are most likely going to KILL your NSTs. What will happen is that because you didn't change the primary capacitor size, it will build up very large voltages (now that you have twice the current) and these transients will kill your NSTs.
You can add another NST in parallel, but you have to make other changes as well.
MOT_man
Sun Apr 06 2008, 06:28AM
Well, I changed a few things on my Tesla Coil today - just the 3.25 " demo coil. I ramped up the primary capacitance to 64 nF and then phased 3 X 12kV 60 mA NSTs on the same circuit... then replaced my topload with a much larger one. 65" thus far not tuned... its getting close to peak output... I'm aiming for 70".
I'll be sending you video - but here is pict of my coil running the dual NSTs 12kV 120mA - 32 nF cap... smaller topload...
Strikes were 50" at peak --- that streamer goes far off the screen ... I'll upload another picture soon
1207463287 1127 FT42314 Img 2086
I'll give an update - just finished the tuning and I cranked out another 12.5" inches. So now I'm up to 70" output ---- .... okay so I must be at near peak output now.... guess the gap needs to be better quenched....
My 14.4 kV PT coil is much easier to run... and MOTs were effortless... but NEONs .... I don't really enjoy them much. So much RF protection - phasing issues.... ;)
MOT_man
Mon Apr 07 2008, 03:07AM
Ultra7 wrote ...
SteveC wrote ...
Kill an NST by paralleling them... no, not in my experience. Buy hooking the capacitors up across the transformers - yes you'll kill the NSTs for sure - or by not using a terry filter. I've seen some big NST banks - 12 kV 300 mA / 600mA --- pretty stupid if you ask me, but it does its job.
SORRY ABOUT THE DOUBLE POST - WON'T HAPPEN AGAIN.... my mistake.
