  • Guests: 60
SGTC mathematics help
watchingthenight
Sun Mar 30 2008, 10:01PM Print
watchingthenight Registered Member #904 Joined: Mon Jul 16 2007, 03:15AM
CORRECTED
Hi,
I am producing my first SGTC and have doing the math but I am unsure if what I am finding is correct seeing as how
I have no experience. So far by using the Javascript Tesla Coil Calculator I have been able to determine:
Transformer:
15kv 30mA 500000 Impedance and .00531 Mf Resonant Capacitor
Secondary Coil:
3577ft of wire 69khz resonance
Cap reactance:
sec coil resonance: 69Khz Reactance: 434.783 Inductance for primary: 1002.867 mH
Now while all of this math makes sense I'm not sure if the numbers I selected for the secondary are appropriate. Using the spark length equation then my max length theoretically is 36.1" and so I assumed that my secondary should be about 25 AWG Cu wire, 3577 feet is what I have at hand for the AWG.
Any tips would be immensely appreciated, also I am not looking for instructions for construction, I have produced circuits in the past and know what I am doing I just lack knowledge in this field in terms of what parts to use. I am basing my ideas off this schem in case anyone is wondering,
Also, I was wondering how should I go about increasing the spark length, I would like something over 8'+
Kizmo
Sun Mar 30 2008, 10:05PM
Take a look here Link2
Coronafix
Sun Mar 30 2008, 10:22PM
What size secondary are you going to use?
Nice transformer by the way.
watchingthenight
Sun Mar 30 2008, 10:27PM
@kizmo thanks for the link I'll look through it
@Goldsphere I don't understand what you mean do you mean in terms of length of the pipe or amt of wire or something else?
I'm thinking something like this for the secondary
do you think it would be appropriate?
Ultra7
Sun Mar 30 2008, 10:43PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
I use Teslamap.
You just plug in all your values and it tells you where to tune.
It has a MMC calculator and other goodies.
Also, where did you ever find a 15K/200mA Transformer?
Is this a NST with the shunts removed, or is it some special build?
When we say "what size is your secondary," we usually mean the outside diameter of the tube and the winding height.
watchingthenight
Sun Mar 30 2008, 11:08PM
CORRECTION: the transformer is 15kv but at 30mA not 200mA that was a mistake by me I just double checked it so I'm sorry for misleading anyone. I did update the first post for anyone who takes a look.
Thx for the tesla map thing I am going to try it out. the size of the od on the sec coil is going to be 6in and the height 4ft but I'm unsure if these are good ideas
Coronafix
Mon Mar 31 2008, 12:41AM
30mA....oh
I was gonna say, i've never heard of a 200mA NST before.
You are probably better off with a 3-4 inch diameter secondary
with a 5 or 6 : 1 winding ratio.
That ebay secondary looks nice but the person obviously doesn't know much about
Tesla coils, I'd suggest wind your own.
bob golding
Mon Mar 31 2008, 12:49AM
bob golding Registered Member #1084 Joined: Mon Oct 29 2007, 08:58PM
to get 8 feet of spark you are going to need around 3 kw input power. you can do this with 4 MOTs and a static gap if you keep run times short. the secondary will need to be around 10 inches long and 5 foot tall. you want around 60 nF of cap for that. good luck with the small one.
watchingthenight
Mon Mar 31 2008, 01:00AM
when you say 5:1 ration I assume you mean Secondary to Primary but what should be the form and height do you think? (I'm trying to solve this on my own but I'm still pretty lost)
Ultra7
Mon Mar 31 2008, 01:29AM
Ratios mean your secondary diameter, by winding height.
A 4 inch coil (4inch = 4 to 4.5 outer diameter) would do well with a 5 to 1 ratio to a 4.5 to 1 ratio.
Meaning. . .
4 inch OD (Outer diameter) to 20 inch winding height. with about 24 gauge Magnet wire.
That SUPER Secondary on Ebay probably would be impossible to tune without ridiculous primary turns.
