  • Guests: 63
Primary??
Alexandre
Sat Mar 29 2008, 06:11PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
The wire of the primary, which is usually used tube of copper, can be replaced by aluminum tubes? confused
Sat Mar 29 2008, 06:31PM
yes smile
Alexandre
Sat Mar 29 2008, 07:03PM
The result is the same?
I liked the aluminum because it is cheaper tongue
Thanks
Avi
Sun Mar 30 2008, 07:57AM
yes it just needs to be a good conductor of electricity, which it is. The more current the larger the magnetic field it generates, which is what transfers power to your secondary coil.
The inductance (which determines the frequency it will oscillate at) is determined by its size, spacing, and turns etc.
Alexandre
Sun Mar 30 2008, 01:45PM
mmmmmm ok I will try to use aluminum cheesey
Sun Mar 30 2008, 03:31PM
Aluminum will only be able to conduct about 2/3 of the current of copper, but shouldnt be a problem?
Kizmo
Sun Mar 30 2008, 03:33PM
But aluminum has greater skin depth so it compensates higher resistance :)
Bjørn
Sun Mar 30 2008, 07:32PM
Here is some nice math and a table about the skin effect: Link2
Alexandre
Sun Mar 30 2008, 11:13PM
niceee
