  • Guests: 45
Sombrero, crown or halo - you choose
Tesladownunder
Sat Mar 29 2008, 02:06PM Print
A new setup I have been working on for a while. Can you work out how it was done?
TDU
1206799595 10 FT0 Hvrotatingcrownyellowss
Ken M.
Sat Mar 29 2008, 02:08PM
Future'istic full body radial scan with nurons.
Sat Mar 29 2008, 05:56PM
Maybe the eye of sauron....And perhaps a computer special effect?
Ultra7
Sat Mar 29 2008, 09:09PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
My guess. . .
I see suspension wires on the outer edge of the halo, so I must assume that you used your nifty rotating breakout thingy suspended above your head arcing to the suspended outer ring.
The gold effect is your colored camera filter. . .
Sat Mar 29 2008, 09:20PM
Im going to have to agree with ultra7 but with the addition of you fired the flash first so your face showed in the correct colour.
Tesladownunder
Sun Mar 30 2008, 01:51AM
That's about how it was done.
The HV supply is my ZVS flyback multiplier running a 4 inch spark.
The rotating motor is the same one off the Tesla coil on a car one, but modified to allow a central earthed electrode and an outer high voltage one.
The run is done as follows:
Rotation on, orange filter on, sparks on, camera triggered by me remotely to run 15 seconds. At 10 seconds, sparks off, filter off and at 15 seconds flash fires to give natural facial lighting.
You can see the reflection of my son (closer and larger) and my wife (smaller) on the variac in the reflection in the stainless steel ball.
BTW all my photos are single exposures with no computer effects/photoshopping.
TDU
1206841744 10 FT42187 Hvrotatingcrownsupply
1206841744 10 FT42187 Hvrotatingcrownpolystyreneball
