  • Guests: 55
New SSTC - COMPLETE
Linas
Sat Mar 29 2008, 01:57PM Print
Hi guys smile
here is my second Tesla coil, powered by full-bridge self resonant with CT feedback, running normally 2000W cheesey
pictures:
1206799016 1143 FT0 P1390020
1206799017 1143 FT0 P1390023
1206799017 1143 FT0 P1390034
bluemotion
Sat Mar 29 2008, 02:53PM
bluemotion Registered Member #1200 Joined: Mon Dec 31 2007, 01:43PM
Awesome! I like the case, it looks so neat.
teslacoolguy
Sat Mar 29 2008, 04:55PM
that has got to be one hot plasma arc
Alexandre
Sat Mar 29 2008, 06:03PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Verry good cheesey
Linas
Tue Apr 01 2008, 06:44PM
hey, with this coil get mote than 4000W power, it is lot of amperes, so 1 minute run kill mosfet's (one side, 1/2 bridge was dead ) spark 50cm suprised just put bigger toroid cheesey
hvguy
Fri Apr 04 2008, 09:44AM
hvguy Registered Member #289 Joined: Mon Mar 06 2006, 10:45AM
Nice coil, good work! Do you have a schematic? I'm curious to see how your starting it...
Linas
Fri Apr 04 2008, 01:11PM
hvguy wrote ...
Nice coil, good work! Do you have a schematic? I curious to see how your starting it...
here it is :)
hvguy
Fri Apr 04 2008, 08:23PM
Thanks. So did you end up sticking with the 74HC14 driver or going with the PLL?
Linas
Sat Apr 05 2008, 09:08AM
hvguy wrote ...
self resonant 74HC14 feedback CT (current xformer ) smile
pll don't work angry
hvguy
Mon Apr 07 2008, 09:18PM
PLLs belong is FM radios, not tesla coils wink Although Steve C. really seems to like his, and it does appear to work for him. I did get one working in both a DRSSTC and an SSTC once but they were just too sensitive.
You’re running some really high power levels for that feedback circuit. My experience has been the feedback loop performance improves with higher output power levels. Generally I’ll see better ZCS and improved stability. Have you noticed this as well? How do your start the system oscillating?
