  • Guests: 64
14 miilion volt TC
Hrothgar
Wed Mar 26 2008, 09:22PM Print
Hrothgar Registered Member #1180 Joined: Mon Dec 17 2007, 12:26AM
Hello to all, and no I've not built it yet, but I wan't to build it. Girst thing however is what should I use to power it, and how much copper do you think it will eat up, because I don't want to spend over $1000 on copper alone (Ill probably end up manufactoring the caps.)
Wed Mar 26 2008, 09:28PM
Do you realise that Tesla coils produce much less voltage than would be needed to break down the same distance as the streamer length with DC voltage? A 14 Megavolt TC would, well, probably produce some 50 (or more) meter streamers (that's my best guess).
Ken M.
Wed Mar 26 2008, 09:31PM
I imagine you easily surpass $1000 for a copper, for the fact that with the sheer size of a secondary youd need would probably require like 16 or 14 gauge wire at a few thousand feet and from what I payed for last time with 6K feet of 30AWG and 3K feet of 28AWG wire at 60$.
Kizmo
Wed Mar 26 2008, 09:43PM
It would take several hundreds kVAs to get even 10MV
lpfthings
Wed Mar 26 2008, 10:07PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Ummm lets see, i think youd need something like 20 pole transformers in parallel?!?!?! I hope you dont intend to run this at your house, youll blow the substation fuse cheesey
Ultra7
Wed Mar 26 2008, 10:21PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Worlds biggest Tesla Coil???
50Ft streamers. . .
Hrothgar
Wed Mar 26 2008, 10:26PM
hmm, maybe not 50ft streamers then, what I really want is to build a machine that puts out 14' streamers, my current TC can only put out a 14" streamer at best, I need a more powerful machine, but all I have is a few kilometers of 28 gauge wire
Logan Kennedy
Wed Mar 26 2008, 11:21PM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
Haha, that's insane!
You'll need an array of KW diesel generators to generate that much power, and even then, it'll require tons of work and money.
These are what we call "pipe dreams." wink
Dr. Drone
Wed Mar 26 2008, 11:41PM
shades
RogerInOhio
Thu Mar 27 2008, 03:55AM
RogerInOhio Registered Member #1034 Joined: Sat Sept 29 2007, 12:50PM
For a coil that size the wire might cost several hundred dollars for the secondary. 28 gage wouldn't cut it, would have to be closer to 18 gage.
You might be able to get a good deal on some aluminum wire but it might not work as good as copper.
