  • Guests: 57
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Best CT for SSTC :)
Linas
Wed Mar 26 2008, 04:15PM Print
Hi
I am making SSTC with 74HC14, i don't want to make antenna, because i want that everything will be in box, so CT is best solution :)
With CT is better ? more windings or 60 ?
1206548145 1143 FT0 Untitled
Wed Mar 26 2008, 05:31PM
You have to bound your question a bit better than that.
Kind of like asking what kind of vehicle do i need to transport my box.
Well, is your box a 1kg box, a box full of rocks weighing 1000kg, or a box holding 20 vehicles weighing well over 50000kg???
Linas
Wed Mar 26 2008, 05:45PM
look, i have ~3000W 74HC14 controlled SSTC,i need that all electronics's should be in my sstc box, so i decided to use CT for secondary feedback, i try 60T CT, sstc work's good, but maybe with 120T CT will be better, so i asking which CT is better, ferrite core are same confused
SSTC parameters:
3000W full-bridge
primary 12T secondary up to 1200T
two modes:Full Wave no interrupter, no cap and Interrupting with 500uF cap
neutral
1206554403 1143 FT41982 P1390004
Ken M.
Wed Mar 26 2008, 09:34PM
I doubt it makes a difference considering all it does is sense the current flow from TC gnd to Earth gnd and produce a P-PV so if you reduce the # of turns you increase the Voltage the CT puts out.
Dr. Drone
Wed Mar 26 2008, 11:26PM
shades
Tom540
Wed Apr 02 2008, 04:12PM
Tom540 Banned on 3/17/2009.
Wind the CT so its resonant at the frequency youre using. For me its about 200KHz and which is 60 turns for the cores I use. It works very well.
