  • Guests: 44
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Input requested concerning microwave oven transformer to charge cap.
Will1234
Mon Mar 24 2008, 11:22PM Print
Will1234 Registered Member #846 Joined: Tue Jun 19 2007, 08:04PM
Hi all,
I’m circling back around to take another shot at reducing the time it takes to charge my 1kv YAG laser flash lamp capacitor. This time I have a MOT in front of me rather then a 6.5kv bug zapper transformer which current limiting makes less desirable.
Instead of trying to use the zapper transformer with it throttled back to 1kv and limited current the MOT cut back to 1kv without current limiting has to be better in reducing cap charge time.
With respect to the MOT what precautions should I take when mounting it since the frame is one side of the secondary high side? Currently I have the whole system attached to pieces of clear Lexan with angle aluminum at the corners forming a rectangular box. This box is then fit into a 4 inch wide green ammo can. If the transformer frame is a terminal of the secondary should I take steps to keep it isolated from the metal can or would it matter as long as the other terminal is kept away from the can? If I mount it like I did the zapper transformer the bolts holding the transformer frame would be near the can. However it was originally bolted to the oven chases which is touched.
If it warrants extra attention, what additional steps should I take to isolate/insulate the MOT as it would be mounted in the can? I don’t want to split hairs but I also don’t want to overlook something that could be of life saving importantance.
Eartaker
Tue Mar 25 2008, 04:03AM
Eartaker Registered Member #150 Joined: Sun Feb 12 2006, 09:43AM
If you don't current limit the MOT it will act as a short circuit pulling 20-30A you need to limit the current on the primary side of the MOT
ramses
Thu Mar 27 2008, 03:33PM
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
i think you could not worry about insulating the core from the case if you earthed the case, maybe using the safety ground of the power outlet you plug it into. as for current limiting, think 100 watt lightbulbs.
ramses
teravolt
Fri Mar 28 2008, 04:15AM
if you want only 1000v you could find a transformer that does 120 to 480 and add a fullwave dublier and that should put you on the mark. the size of the transformer and caps will determin how fast you can recarge. ebay is a good source for step up transformers
