  • Guests: 28
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Secondary coil windings and height
Mon Mar 24 2008, 02:07PM Print
Ive read deepfriedneon's guide to build a tesla coil, and he descripes some diameters, heights and number of windings of the secondary coil.
With my limited ressources I can make a 100cm tall / 11cm diameter secondary coil, winded with some isolated 0,5mm^2 wire, would give me 500 windings, would that be a useful coil? I know that if they are too small they will strike to the primary coil, but can they get too tall?
Mon Mar 24 2008, 02:51PM
MadsKaizer wrote ...
you meant 0.5mm diameter? If my calculations are right you would get 2000 turns not 500. If you really meant cross-section then it's a bit less but still over 1000.
Mon Mar 24 2008, 02:56PM
Plasmaddict wrote ...
I meant crosssection the copper is 0,5mm^2, with isolation its about 2mm diameter
MOT_man
Mon Mar 24 2008, 06:03PM
Well, too many winding = higher than normal resistance. I have a very tall 3.25" X 40" secondary. It is wound with 27 AWG magnet wire.... and produced lovely discharges at 2 kVA. It has the same level inductance as my 4" secondary. So just because you have over 1800 turns doesn't mean the coil won't fire. But do be careful not to go too over board.
Mon Mar 24 2008, 07:02PM
MOT_man wrote ...
I guess the resistance wont be a problem with 20 AWG then
Mon Mar 24 2008, 07:03PM
Ok, but with that thick insulation you may not be getting the optimal power from the coil as this thin wire will overheat much sooner than if it was solid copper with just a thin enamel.
Really i would suggest you to go to your local motor rewinding shop and ask for some wire, it is really not THAT expensive.
MOT_man
Mon Mar 24 2008, 10:07PM
overheat? How much power is put through the coil? Hell, if I run my 27AWG wound 3.25" X 40" secondary at 2 -3 kVA at it doesn't overheat why would his? I'm getting beautiful discharged - the windings are cool to the touch.
