  • Guests: 66
PlasmaSonic SSTC Help
dicban
Mon Mar 24 2008, 12:30PM Print
dicban Registered Member #790 Joined: Sun May 20 2007, 12:03PM
Hello Everybody
I have some questions about this SSTC
In this two schematics there is some kind of feedback
1.Can someone explain me how this feedback work?
2.And how would this SSTC work with and without this feedback?
Thanx
Mon Mar 24 2008, 03:10PM
Its a very crude way of adjusting the frequency to help re-tune the system as the arc grows. It doesn't work very well, nor is it really needed.
Basically, as your bus voltage decreases (i.e. more load and longer arc), the voltage will vary at the freq adj pin on the TL494 and vary the frequency a bit.
Richie Burnett first used this in his earliest SSTCs. It was just carried over and never really determined (at least by me) to be worthwhile or not.
dicban
Mon Mar 24 2008, 03:47PM
Ok, Thanx
Ill try that schematic, It cant hurt to try that feedback.:)
Mates
Mon Mar 24 2008, 09:19PM
Just be careful, once you tune your coil with the feedback do not disconnect it while it runs on full power and vice versa(always tune again using lower power), it shifts the freq quite a lot and running the coil out of resonance can have a fatal consequences...
Otherwise, in my hands this feedback works quite well mainly for higher power SSTC, but you need to earth-ground your driver schematics which can be problematic in some cases.
Cheers
dicban
Mon Mar 24 2008, 09:40PM
Ok Thanx for reply, I will try that schematic
I was thinking about building Stereo System with Audio tesla coils using this schematic
bit I dont know if I will be able to do that.
I dont have much experience in that stuff butt I will try.
