  • Guests: 75
where does the e- come in?
Hrothgar
Sat Mar 22 2008, 07:57PM Print
Hrothgar Registered Member #1180 Joined: Mon Dec 17 2007, 12:26AM
Sorry if this is stupid, and before you rip my head off for not doing my own investigation, I DID!
Where are the electrons coming from in my secondary? I understand that it works, but why?
changing current=changing field changing field makes changing current, how come?
Josh Johnson
Sat Mar 22 2008, 08:34PM
Josh Johnson Registered Member #793 Joined: Sun May 20 2007, 06:50PM
Super simple answer:
The electrons are in there already, the changing magnetic field just moves them around.
Hrothgar
Sat Mar 22 2008, 08:38PM
then the magnetic field of the primary pulls them into higher energy orbit?
how, why?
Myke
Sun Mar 23 2008, 02:12AM
Not the higher energy orbit. They just get moved through the conductor.
When air is ionized the electron go to a higher energy orbit. When they jump back into the lower energy orbits they release a photon.
Is this right?
Electroholic
Sun Mar 23 2008, 03:02AM
The is a sea of free electrons in the metal structure. B field pushes them around to create E field. Have enough E field and you rip electrons off air molecules.
Avi
Sun Mar 23 2008, 05:26AM
As you move the move a magnet around a conductor (eg a copper wire) it will shift the electrons from atom to atom.
Now imagine this happening along the whole conductor, now you have an electron flow.
As you can imagine, they only move when you move the magnet.
that is why you need a changing magnetic field to create a 'flow' of electrons, otherwise they are still (staying in their atom) and there is no current.
Hrothgar
Sun Mar 23 2008, 01:38PM
thanks, I was concerned when I opened up my text books and all they ever said was, changing magnetic field make currents!
