  • Guests: 38
11/25 Chris (40)
11/25 JamesH (18)
11/25 Oakley (22)
My Airgun
flannelhead
Fri Mar 21 2008, 04:15PM Print
Ok, so here's my high-energy homemade airgun.
1211467104 952 FT1630 Cannon
So it consists a 1,5L pop bottle, a car valve stem, a ball valve and a barrel. The ball valve is closed, and the bottle is pressurized through the car valve. A projectile is put into the barrel and the barrel is screwed to the ball valve. Then the ball valve is opened and the air pulse accelerates the projectile through the barrel.
My barrel is currently a bit too short to efficiently use all the energy stored in the bottle. Wait until I get a longer barrel... shades
For a projectile I use a small piece cut from an eraser and covered with tape to fit tightly in the barrel.
I've recorded a short video of it shooting a cardboard box. There's also a slo-mo gif animation to see what actually happens.
You can also post your own pneumatic toys in this thread.
flannelhead
Sat Mar 29 2008, 11:24AM
I've made some measurements with the air gun. I measured the speed with 3.5 meters distance between the gun and the target. The average speed with a 12 gram projectile was 20.5 m/s. Not too bad! I calculated the kinetic energy of the projectile and it's 2.5J
coldcity
Sat Mar 29 2008, 11:31AM
coldcity Registered Member #1406 Joined: Thu Mar 20 2008, 12:12PM
I really like the pneumatic gun :) I'll have to keep an eye out for old bike tyres to salvage a valve.
huzbum
Wed Apr 16 2008, 03:55PM
huzbum Registered Member #1439 Joined: Sat Apr 12 2008, 03:25PM
What sort of valves are you looking for? I work at a tire dealer...
flannelhead
Thu May 08 2008, 01:40PM
You can get valves from any bike/car tire. The ball valve (the one used to trigger) is from Bauhaus. It cost 6,70€.
I also updated the top post.
Spedy
Thu May 08 2008, 03:29PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
You could make this pneumatic spudgun a heck of a lot more powerful, just make a better valve like the modified sprinkler valve Link2
These open lots quicker than your ball valve can and you'll get better performance =)
ps: If you feel up to it, you could take it another notch higher and build your own piston valve. look around the "How-To Database" at that website, there's tons of diff. ways to make them
flannelhead
Thu May 08 2008, 05:26PM
Spedy wrote ...
Actually the ball valve can be opened pretty quickly smile And I like to Keep It Simple, so no valve modding. The pressure in the vessel quite forces the ball valve to open.
Lakeowner
Thu May 08 2008, 06:22PM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
I notice some equations with my own airgun project, Link2 ... :) Sadly it is written in finnish.
lpfthings
Fri May 09 2008, 09:56AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Nice cannon! If i ever made one of these, i would design it to fire little hard orange berry things, they are all over the place here. Going by yor words, it seems pretty powerful. Got any vids/pics of the projectile going through something?
flannelhead
Fri May 09 2008, 12:32PM
Laakkonen wrote ...
Actually I got some inspiration from your project wink You also seem to have noticed that the all-mighty hot glue doesn't work in this kind of purpose.
lpfthings wrote ...
The projectile is a bit too fast for my camera. It can do 60fps though, but with poor quality. I'll try to get some clips.
