  • Guests: 67
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Doubler
Alexandre
Fri Mar 21 2008, 03:54PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Hi All
Constructs a Doubler with a trafo he had here, follows the photos.
1206114373 1228 FT0 Pict0175
1206114373 1228 FT0 Pict0171
1206114373 1228 FT0 Pict0177
Look the MOT on the firt picture
I use for a Charging Choke,
I am using a Trafo of 2000 +2000 V = 4Kv For the entry of high voltage
And Doubler for 8kV, one MOT serves as Choke? Or will need two?
thanks
Fri Mar 21 2008, 04:43PM
You will need two just for them to handle the voltage and to bring thwe shorting current down.
Great setup by the way!
Alexandre
Fri Mar 21 2008, 07:32PM
I think we have two MOT, it is to limit the current, but the current output of the trafo is 300mA, it is 1.2KVA, but even then I put two to be sure. cheesey
Thanks tongue
Not Resist and tested my doubler today tongue
Using an MOT as CHOKE, the beginning was fairly, the arches appeared excellent, but after the third arc, gave a bloww, caps discharge violently in the output of the doubler. confused
After that BLOWW not stopped more than anything, was that see the smoke in CHOKE, isolation is broke. cry mad
Then tell me, two MOT as choke solve my problem?
I doubler 4KV @ 300mA shades
[Edit: Double post]
Sat Mar 22 2008, 01:48AM
You used one mot as the choke? I know that two mot's can handle twice the voltage. Hooking the one mot as the choke is like pushing 4 times the rated voltage through it,or using a 4 pack mot stack. If two are used it will be like a 2 pack mot stack for each mot. And from what the internet says no one,including me,has had a failure with two mot's.
WAIT!
You do know that the chokes go AFTER the doubler,right? I cannot see them on that picture is why i ask...If you did not know,i will tell you right know(so i don't have to type later). The two mot's supplying the voltage is good and the doubler is good but after the positive output of te doubler is were the two chokes go.
Sat Mar 22 2008, 09:13AM
Just asking, have you shorted the primary winding of the MOT?
Alexandre
Sun Mar 23 2008, 12:50AM
The primary of the MOT was disconnected.
Sun Mar 23 2008, 03:21AM
Oh so you have a tripler? Or quadruple?
Alexandre
Sun Mar 23 2008, 03:58AM
doubler
Sun Mar 23 2008, 04:39AM
well if you only have one mot powering it you only need one capacitor and one diode.unless you are using the circuit that has the smoothing cap and then it would take two caps. If you are using one mot as input and a doubler you should only need one choke because one mot choke can withstand 4000 volts easily.
Sun Mar 23 2008, 09:06AM
Tesla Brasil wrote ...
I think it should be shorted so the core does not saturate nearly as easily but I may be mistaken, try to ask someone else
