  • Guests: 46
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Looking for a 30 VDC power supply...
sparky99
Fri Mar 21 2008, 01:53AM Print
sparky99 Registered Member #1159 Joined: Fri Dec 07 2007, 02:10AM
..........20 amps, regulated. A switcher would be nice, but a linear supply would work, just a bit heavy to lug around rolleyes Anyone?
Thanks,
Sparky99
N2OAM
Fri Mar 21 2008, 08:23AM
30V dc is not a common voltage for a power supply,
24V dc is a very common supply voltage for all kinds of industrial systems.
So if 24V is enough look on eBay for '24v power supply' and you'll find many cheap ones (usually)
P.S. many industrial 24V supplies have an adjustment range, so more than 24V is possible.
sparky99
Fri Mar 21 2008, 04:59PM
I thought about that, but then I'm losing 20% or more output power from my co2 laser. I need 30 Volts. I'll probably end up cobbling together a linear (HEAVY!) supply. Anyone make a LM style regulator that can handle 20 amps or do I have to use a bunch of 5 amp regulators?
Sparky99
Fri Mar 21 2008, 05:27PM
Does it have to be so much regulated? Really I would just rewind a MOT (shunts removed), rectify it and filter with big filter caps. If the laser draws steady current then you could design it to output 30V loaded (it would probably be a few V more unloaded)
