  • Guests: 52
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Dimmer??
Alexandre
Thu Mar 20 2008, 04:21PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
I am willing to use a DIMMER with triac, instead of variac, it is stronger, but by studies that did, it has a serious defect, the interference.
For that reason, I put this filter.
Will it work??
1206029974 1228 FT0 Filtrovariac2
Thu Mar 20 2008, 07:31PM
Maybe you should also consider a MOV (Metal Oxide Varistor) on the "LOAD" side to catch any voltage spikes before they can get any further.
Tom540
Fri Mar 21 2008, 02:34PM
Tom540 Banned on 3/17/2009.
Perhaps you could use both common mode and differential mode chokes.
