  • Guests: 33
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Just a thought about sstc and vttc.
Thu Mar 20 2008, 01:21AM Print
Is there any way to make Steve Wards 811A vttc circuit work with a mosfet? Without any circuit changes? I would be greatful if someone could drop me a line. Someone on this forum said something about just changing the negative bias into positive or something. I dont know. But surly it is possible considering the vacuum tubes and mosfets are both electronic 'valves'.
Thu Mar 20 2008, 01:31AM
A MOSFET is just a functional analogy to a Triode tube, they are not drop in replaceable. For one thing, the grid voltage requirements are entirely different for a triode and a MOSFET. Stick a MOSFET in place of that 811A with Steve's circuit, which if i remember correctly used a grid leak biasing network to turn the tube on/off, and you'll blow that MOSFET to smithereens!!!
flannelhead
Thu Mar 20 2008, 01:14PM
Arcstarter wrote ...
There was something like that on the old forum: Link2
They got a IRFP460 working straight from a feedback coil!
coldcity
Thu Mar 20 2008, 03:17PM
coldcity Registered Member #1406 Joined: Thu Mar 20 2008, 12:12PM
Aha - I was wondering if the replace-triode-with-MOSFET technique familiar to me from audio stuff would be applicable for a coil.
Lots of info about this substitution (for audio use) at Runoffgroove.com in general and here specifically. J201's are very popular in that application; I'm going to experiment with similar techniques for high power using possibly 2SK899's, which I have a bunch of.
Anyone else have thoughts on this?
Thu Mar 20 2008, 04:17PM
I've played around with JFET and valve preamps too. The valve-to-JFET substitution works (sort of) because these are small-signal Class-A circuits.
Since the 811A runs off something like 2kV, the plate voltage goes to at least 2 times, maybe pi times the supply voltage, and nobody makes 6kV MOSFETs, you are doomed to fail unless you lower the voltage, which is a circuit change. After a few more circuit changes, you should end up with something not unlike Steve Ward's Class-E micro SSTC.
Thu Mar 20 2008, 04:25PM
I just mean use the same basic circuit meaning a royer oscillator or what ever it is called. I know 2kv is way above operatic characteristics of any mosfet. I just heard someone say it could happen if you change some stuff up. Spark had the right forum. Read it and mabey you will see what they mean..I am a little stupid when it comes to substituting parts..
coldcity
Fri Mar 21 2008, 01:13AM
Ah yes, I meant JFET :)
Sat Mar 22 2008, 07:24PM
They can sing?! cheesey
Seriously though, FETs are like tubes in the same way that a Geo metro and a monster truck are both cars. They need slightly different conditions to show their best. FETs nowadays are designed for switched mode power supplies and can be a bit unpredictable in these simple self-oscillating circuits. They can suffer from thermal runaway, parasitic oscillations, etc, whereas tubes tend to "just work".
I'm currently working on a Fender Bassman-style preamp made of BF245A JFETs cascoded with high-voltage BJTs. I'd never seen the runoffgroove stuff before, and I didn't know about using a resistor on the source to change the square-law characteristic to something more "tubey". It actually seems to work! :)
BTW, I always thought FETs behave more like pentodes...
coldcity
Sat Mar 22 2008, 09:37PM
Steve Conner wrote ...
- Apologies to OP for straying off topic, but check out the Dr. Boogey pedal. It's built from the Mesa Boogie Dual Rec head schem, which is almost exactly copied with the tubes replaced with JFETs and appropriately biased.
It seems like it shouldn't work; yet sounds closer to the real thing than any other analogue/digital/software emulation I've heard.
Simply amazing.
Sun Mar 23 2008, 10:33AM
Ooo, awesome! I must try building that.
In a pathetic attempt to stay on topic, note that it runs off 9v, not 250v like the original did! :P
Also, JFETs are depletion-mode devices, so they can be biased the same as tubes. MOSFETs are enhancement mode: they don't conduct until the gate is brought more positive than the source. So the "cathode bias" trick won't work directly.
