  • Guests: 52
Strantge sstc behaviour
flannelhead
Sun Mar 16 2008, 10:34AM Print
I built Steve W's Micro SSTC circuit (without the starting oscillator) and ran it at 12V, secondary grounded to a plane of metal. The antenna is a 2cm piece of wire. Ok, so when I moved my finger near the antenna, the corona started to act like it were interrupted. What would have caused this?
Kizmo
Sun Mar 16 2008, 11:57AM
Was the interrupting frequency same as your mains freq (50/60Hz)?
flannelhead
Sun Mar 16 2008, 06:35PM
Pretty much like that, I believe. But I ran it off a wall wart, and my circuit had various smoothing caps.
Dr. H.
Sun Mar 16 2008, 07:49PM
"The antenna is a 2cm piece of wire." - is this an error, or is it really so short ? The antenna shoud me longer than that.
Cheers Huben.
Experimentonomen
Sun Mar 16 2008, 10:43PM
The antnna lenght should be matched to the freq of your coil.
Myke
Mon Mar 17 2008, 04:51AM
Wouldn't that make the antenna really really long?
