  • Guests: 37
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
136 Used Disposable Cameras
Backyard Skunkworks
Sun Mar 16 2008, 06:55PM
Well for one thing the caps are rated to 330 volts normally and I've seen a few that are 180uF, a few that are 80uF however the bulk are 120uF or 100uF. I guess they all average out to roughly 120. Given that you have a total of 176 cameras if you charged all the caps to 330 volts you'd actually have around 1,150 Joules.
I've made a bank of 10x 120uF 330V flash caps in parallel for 65.34J, it will fire a little iron rod at several meters per second as part of a coilgun and it will vaporize a good bit of aluminum foil if shorted across it.
I'd say a CW multiplier would be a great idea however anything done with more then five of these caps should be treated as a lethal shock hazard if they are fully charged. If you were to get maybe 150 joules at a couple kV you really might be able to use the thing like a defibrillator, but this would be a sure way to earn a darwin award. Can crushing, wire exploding guns, electric fishing, all of that is possible with a big-@$$ load of photoflash caps. It would also be cool to discharge them into some uber huge step-up transformer and get a crazy high voltage, crazy high current pulse.
Sun Mar 16 2008, 07:04PM
I like the monolith flash idea, perhaps you could use it to quickly cook small meals.
teslaguy
Sun Mar 16 2008, 11:10PM
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
Backyard Skunkworks wrote ...
I'd say a CW multiplier would be a great idea however anything done with more then five of these caps should be treated as a lethal shock hazard if they are fully charged. If you were to get maybe 150 joules at a couple kV you really might be able to use the thing like a defibrillator, but this would be a sure way to earn a darwin award. Can crushing, wire exploding guns, electric fishing, all of that is possible with a big-@$$ load of photo flash caps. It would also be cool to discharge them into some uber huge step-up transformer and get a crazy high voltage, crazy high current pulse.
I like the idea of a CW multiplier but I never knew that it could be done with polar caps...I think i might try some can crushing/coin shrinking with them as well, I just destroyed a pair of needle nose pliers with 3 720uf banks in parallel at 270 volts....So i am beginning to realize that these are much more dangerous than I originally thought.
Conundrum wrote ...
hmm.. well it might be possible to make a MMF (Multi Monolithic Flash) module, for high speed photography and/or laser experiments. The idea here is to solder the flash tubes together in a circular array with a reflector behind them, with wires wrapped around the tubes connected to your HV trigger.
I like the flash Idea I dont think i would use it to cook but i might want to try going blind for a week at some point just for fun.... The geiger counter also seems like a cool experiment. I think im going to get back to soldering the capacitors together...I might also try to build a mini telsa coil from a couple of the camera transformers. I think I will get about 100 more cameras tomorrow (im going to go home a different way). I will update you guys with some pictures of my progress and the new cameras if i do. Thanks so much again for all of the use full ideas and feedback.
Backyard Skunkworks
Sun Mar 16 2008, 11:35PM
halomaster2004 wrote ...
If your using AC input then you can't build a CW with 'lytics, however I was thinking pulsed DC input in which case I think you can. Someone correct me if I'm wrong here.
EDIT: I've broken a couple xenon tubes prying 'em out, I can't imagine de-soldering would even come close to breaking them.
EDIT: Electrolytic caps do work in CWs, as explained by Shaun.
Shaun
Mon Mar 17 2008, 03:35AM
Actually BS, polar capacitors can be used in a CW system. In fact I'm also pretty sure that pulsed DC will not work at all.
The only thing here is you cannot short the capacitors, as then they fully discharge at very high current through the diodes. A limiting resistor is usually used here to limit current. On the CW system Mates made, his strings of 1n4007s took quite a few full discharges and kept on going, but you may not be so lucky.
Backyard Skunkworks
Mon Mar 17 2008, 04:20AM
Looking at how a CW is put together I think pulsed DC would work aswell, because the latter stages seem to be getting charged through diodes. Wikipedia claims this is true aswell "The CW is basically a voltage multiplier that converts AC or pulsing DC electrical power from a low voltage level to a higher DC voltage level." Link2
Looks like its the single stage voltage doublers like the one described in the first part of the 4hv wiki's CW page that cant use 'lytics.
teslaguy
Mon Mar 17 2008, 09:08PM
Im going to try right now with a couple capacitors at a low voltage. If that works Ill post my results. Also I received thanks to my cunning abilities as a student about 40 or 50 more cameras today on an alternate route home. Tomorrow I might go home from school yet another way!
flannelhead
Tue Mar 18 2008, 01:07PM
How much of them are you going to get?? amazed
Another idea:
Rip all their inverters off the boards and wire some in series and some in parallel. Then make a "disposable camera tesla coil" like I did: Link2
teslacoolguy
Tue Mar 18 2008, 04:52PM
do like i did and bank 98 of the caps up and make a 450j capacitor bank to blow stuff up with smile
