  • Guests: 61
suitable caps?
bob golding
Sat Mar 15 2008, 01:04AM Print
bob golding Registered Member #1084 Joined: Mon Oct 29 2007, 08:58PM
hi all,
after searching ebay i have found what i hope are some suitable decouping caps for my proposed drsstc. 3800uF 400 volt or 5800uF 400volt. i am limiting myself to what i get from a doubler from the 240 volt mains and 16 amps. would 4 of these be a good start. i already have 10 1000 UF 250 volt caps for the doubler. i like arons coil but maybe i should start with something a little smaller.
cheers
bob
Bennem
Sat Mar 15 2008, 06:16AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi Bob,
I would say thoughs storage caps would be fine,
Just make sure they are good quality caps.....low ESL, ESR.
Thats a big coil you propose to build for your first DRSSTC!
Yes...Arons DRSSTC coil was a great thread to read about,
but even with his low inductance lay out, he had problems with transients
killing IGBTs over a certain mains voltage even though his IGBT's were rated,
if i remember at 1200 volts....so you might not want to turn up your doubled storage voltage
too high.
just my pennys worth..... smile
All the best with your project and i look forward to seeing more info on it!
Mel.
Dramo
Tue Mar 18 2008, 05:39PM
Dramo Registered Member #1402 Joined: Tue Mar 18 2008, 05:19PM
I wouldn't like to make new topic out of this so I ask here:
Would these caps be decent for a mmc ?
