  • Guests: 31
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
Taser
Bjørn
Thu Mar 27 2008, 03:33PM
I remember reading somewhere that you cant feel AC past like 10khz yet it still paralyzes.
No, the nerve receptors are not sensitive to high frequencies so you are not affected. You can pass enough current to cook yourself without feeling anything.
If the current causes ions to wander from one place to another then muscles will be paralyzed but that usually takes some time, at least with AC.
kerver
Sun Apr 06 2008, 08:42PM
kerver Registered Member #522 Joined: Thu Feb 15 2007, 01:04AM
wink the m26c puls wave form circuit
Jpg
lamazoid
Wed Apr 30 2008, 06:25PM
lamazoid Registered Member #573 Joined: Fri Mar 09 2007, 11:26AM
Well if anoyne wants to make a stun gun based on taser principle operation but much more effective, you should go here:
The original taser actually have very poor efficency itself, but with its darts shooted it icreases current path which really makes the effect.
Fri May 02 2008, 11:55PM
I once obtained a few secondaries for "research" purposes :) however they appear to be rejects as the epoxy is very badly potted. However the plan was to use them for Lifter research or powering small lasers...
-A
