  • Guests: 55
RoV IW3IPD (63)
01/13 si2030 (62)
any opinion in designing dc-dc converter using CMOS
chek
Thu Mar 13 2008, 03:59PM Print
chek Registered Member #1373 Joined: Tue Mar 04 2008, 12:45PM
hi everyone..i got a task to design a high voltage dc to dc converter using CMOS...anyone got suggestion what type of CMOS i could use and what the main things need to be considered in designing this type of circuit..
Thu Mar 13 2008, 05:25PM
Not enough information, e.g.
Input Voltage
Output Voltage
Output Current or Power
chek
Fri Mar 14 2008, 04:42PM
the input voltage of the circuit is 10V, the output is 200V and the output current is 512microampere... please give some opinion..
Fri Mar 14 2008, 04:45PM
why do you need to use CMOS? If you really have to, I would use the CMOS version of the 555 to drive a MOSFET and a high frequency ferrite transformer. 100mW is really not too much power...
chek
Sat Mar 15 2008, 05:39AM
jmartis
Posted: Sat Mar 15 2008, 12:45AM
can you give me more example about this...
Sat Mar 15 2008, 08:19AM
chek wrote ...
jmartis
The simplest thing I can think of now is a 555 oscillator (you can find schematics on the net) driving a MOSFET with at least 300V rating, this MOSFET switches an inductor which creates high voltage spikes on turn off, these spikes are then rectified and filtered (search "boost converter").
How well does it need to be regulated? For simple output adjustment just change the frequency (higher freq. -> lower output), if you want it to be stabilised then you can make a resistor divider and one transistor which pulls the RESET pin of the 555 LOW when the output voltage has reached 200V.
chek
Sat Mar 15 2008, 10:33AM
this was the things that i need to be design...A CMOS High-Voltage DC-DC Up Converter Dedicated for Ultrasonic Applications...
]4-iwsoc04.pdf[/file]
any opinion??
Tue Mar 18 2008, 10:37AM
The converter in that paper is fully integrated on a chip with no external magnetics or anything. Is that really what you want? suprised
