  • Guests: 44
Class E/TVS coil upgrade
Mates
Thu Mar 13 2008, 12:01AM Print
Hi guys,
my old GhettoI (the project discussed here Link2 ) got some upgrade. It has a new primary and I'm also trying a new much bigger top load (runs at 150KHz). It still needs some tuning. It sucks almost 2KW from the wall and it can run 2-3minutes with the fan on. I think it is not bad for BUP314 (two in parallel) Link2 . The temp of all the heat sinks is not critical after two min run, but I feel it can be still better. My problem is I have only one channel scope so proper classE tuning is a problem for me. On the other hand, because of the design, I don't need to care about the fall time of the transistor because the caps are discharged long before the transistor is closing, this allows me to keep the driving pulses very short (1us) which makes the classE tuning relatively easy.
I managed some new nice pictures and a movie so enjoy...
Comments and questions welcomed...
Movie link: Link2
1205366302 1025 FT0 Sg101613
1 Copy
2 Copy
3 Copy
4 Copy
Logan Kennedy
Thu Mar 13 2008, 12:54AM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
Cool!
I've been trying to make the move to E class, but I haven't been able to succeed thus far. I'm beginning to wonder if my o-scope isn't calibrated properly.
Thu Mar 13 2008, 03:06PM
Nice pictures as usual!
No offence but for 2kW you aren't getting very large streamers, are you sure the TVS diodes aren't burning most of that power? If so you should consider fixing your circuit or tuning. When tuned for proper class E, 3x Vin or more can be expected which is within the safe range of your two BUP314s. I would remove all the TVS diodes which are unnecessary for class E. As long as they're needed you're not switching in class E, but class TVS.
Mates wrote ...
Which caps, the class E tuning ones? Their voltage is supposed to just touch zero just as your switch turns on, not before and not after. (Ideally) That's all class E tuning is.
Mates
Thu Mar 13 2008, 04:04PM
Uzzors wrote ...
Yes you right. Those streamers are not very long (max 35cm) - but, it's a new design so it still needs a lot of tuning, mainly matching the resonant cap with the coil is a tricky part (this time my primary is not naked, so I have to try different capacitances which makes the tuning rather difficult). BTW: In case I run only 600W the sparks are almost the same size, but they are not as hot.
Uzzors wrote ...
Mates wrote ...
Which caps, the class E tuning ones? They're voltage is supposed to just touch zero just as your switch turns on, not before and not after. (Ideally) That's all class E tuning is.
That's my mass in explaining things - sorry. So let's make things hopefuly more clear:
The old scheme is here: Link2
The cap I mean is the 300uF motor foil cap used as a power supply. This cap is discharged into the cap/coil resonant circuit after the transistor gets open. This discharge pulse longs less than 100ns. That's why I do not care about the fall time of my transitor and the driving pulse last only 1us. While the transistor is closed my 300uF power source is being loaded from the wall and the resonant circuit makes an AC wave response at 150 KHz (or 180 in my previous setup). It's quite easy to place the 1us pulses between the AC pulses generated by the coil/cap, because half of the wave longs 13us. But, there two important issues here. In the resonant circuit made of the coil primary and resonant cap (aprox. 100nF 5000V) is induced quite a high voltage which once reach a 900V is clamped by the TVS. So the TVS are absolutely necessary and I will never remove them. But would be nice to keep them cold while the coil is running the question is whether it’s even doable? I hope that once I achieve ideal resonance and coupling there will be voltage induction lower than 900V...
Thu Mar 13 2008, 07:18PM
I see. Using a larger resonant capacitor and smaller primary inductance will drop the rise. You should also find some TVS diodes with a clamping voltage closer to 1200V so you don't clip the resonant rise at such a low voltage. Even 1kV would allow for most of the rise if not all of it, although you can probably push the rise under 900V if you try hard enough. cheesey Good luck with the tuning!
Mates
Thu Mar 13 2008, 09:02PM
I decreased the nr. of primary turns (6), and also played with the resonant cap size. I also decided to go back for my old top load - it looks much better.
So, the performance (spark size and heating) seems much better now... wink
1205442125 1025 FT41024 Sg101616
Mates
Thu Mar 13 2008, 10:47PM
(Sorry for double post - admin please join with the previous answer...)
I connected my gate to the probe and left the ground open. I can see the driving pulses and also signal from the running coil (powered at 12V AC in this case). It's a try to show the classE performance using only one channel o-scope cheesey
3 Copy
Here are the driving pulses with grounded probe connection
4 Copy
Here the gound of the probe is left unconnected. You can see on the picture that the AC sinus generated by the running coil peaks right in the midle between the driving pulses (negative part of the sinus is not visible because of the driving pulses)...
2 Copy
And here is one more picture after little bit of additional tuning
Mates
Sat Mar 15 2008, 12:28AM
I’m little bit surprise that my coil attracts so little of interest sad . It has so many advantages to compare to standard half or full bridge designs:
1) Relatively slow (thus cheap) IGBT transistors like BUP314 can be used for freq. up to 250KHz (maybe more)
2) Direct 220V AC powered (no transformer needed)
3) Power regulation (not continual but step like – by adding or removing caps)
4) No antenna or current transformer feedback needed!
5) Stable operation resistant to capacitance environmental changes
6) No dead transistors!
7) It’s a single switch (does not need special demands on driving circuit) and allowing easy transistor paralleling
8) Even totally uneducated electronic beginner (like me) can manage to built it
9) Spark size can easily compete with the best full bridge designs I’ve seen on the net
It would be so nice to get at least somebody on my side and develop this design a bit. I’m ready to help and discuss things…
BTW: After last tuning I achieved cold TVS – finally! Here are the last pictures of sparks and a movie – hopefully a little bit of motivation for followers.
movie: Link2
Cheers Mates
1205540729 1025 FT41024 360uf
1205540773 1025 FT41024 360uf2
Sat Mar 15 2008, 09:10AM
Looks like you've tuned it perfectly! The reason I haven't tried an offline class E coil is that I have piles of IRFP450s which are only 500V devices. If I'm to run anything offline it has to be via a bridge.
Sat Mar 15 2008, 12:08PM
...maibe because it has a precedent (simple enough to build and good performance...the all known Royer SSTC). Even it has not an IC (as TL494) involved.
PROJECT HERE
