  • Guests: 47
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
DRSSTC - questions
flannelhead
Sun Mar 09 2008, 06:09PM Print
So I'm starting to plan a DRSSTC... and I will have a lot of questions about it.
I thought of copying JimG's design:
1140344773 52 FT600 Tinydrsstcschematic
So first question:
Do I REALLY have to use those expensive IGBTs (IRG4BC40W)? Are there any IGBTs that are a little cheaper (<6€) that work in 1MHz-like frequencies? Or should I think about using MOSFETs?
Shaun
Sun Mar 09 2008, 09:48PM
If its a REALLY small coil and you use very large and adequately protected MOSFETs, then yes it can be done. The IRFP260 has a pulse rating of 200A, which is very reasonable for a small DRSSTC.
flannelhead
Mon Mar 10 2008, 01:09PM
Thanks for answer. I think I'll just use those IGBTs. Can you believe that in Elfa Link2 they were 12€ per piece! Then looked at Partco. They seem to have those IGBTs at 4€. That's a reasonable price.
Some other questions:
Do you think disposable camera photoflash caps could be reliable enough for the main HV cap?
Do you know about N27 and N30 ferrite materials? Only those toroids seem to be available in Partco, and I need to know which should I use for GDT and feedback transformer cores. Unfortunately they seem to have high losses with high frequencies.
EDIT: I think I'll have to get 3E25 cores from Elfa. These are good enough and don't seem to be overpriced (as usually in Elfa).
