Acrylic tesla coil secondaries for sale
Logan Kennedy
Wed Feb 27 2008, 04:32AM
Registered Member #1103
Okay guys, I have some more cool stuff to offer.
1. Micro tesla coil secondary - 3" x 1/2" (2 1/2" winding length) -- 33AWG magnet wire
Cost: $5.00 each ($2.50 S&H)
Specs: Diameter of secondary coil : 0.50in Winding height of secondary coil : 2.50in Wire diameter for secondary coil : 0.0071in Spacing between windings : 0.00in Secondary turns : 352.00 Secondary wire length : 46.09ft Secondary inductance : 0.28mH Approximate resonant frequency : 9209.86kHz Secondary quarter wavelength resonant frequency : 5338.58kHz Secondary self capacitance : 1.05pF Toroid capacitance required to form quarter wavelength coil : 2.08pF
2. Mini tesla coil secondary - 5" x 1" (4 1/2" winding length) -- 33AWG magnet wire
Cost: $10.00 each ($4.50 S&H)
Specs: Diameter of secondary coil : 1.00in Winding height of secondary coil : 4.50in Wire diameter for secondary coil : 0.0071in Spacing between windings : 0.00in Secondary turns : 633.00 Secondary wire length : 165.93ft Secondary inductance : 2.03mH Approximate resonant frequency : 2504.95kHz Secondary quarter wavelength resonant frequency : 1482.94kHz Secondary self capacitance : 1.99pF Toroid capacitance required to form quarter wavelength coil : 3.69pF
3. Large tesla coil secondary - 24" x 5" (21 1/2" winding length) -- 21AWG magnet wire
Cost: Send me an offer ($25.00 S&H) - I only have one available.
Specs: Diameter of secondary coil : 5.00in Winding height of secondary coil : 21.50in Wire diameter for secondary coil : 0.0285in Spacing between windings : 0.00in Secondary turns : 754.00 Secondary wire length : 987.49ft Secondary inductance : 14.98mH Approximate resonant frequency : 417.10kHz Secondary quarter wavelength resonant frequency : 249.18kHz Secondary self capacitance : 9.72pF Toroid capacitance required to form quarter wavelength coil : 17.52pF
I'll apply 2 to 3 coats of clear polyurethane varnish on the secondary only on your request (anymore is extra). Otherwise, I will ship them with one coat of varnish (to protect against temperature change). The windings are tight and without gaps. What you see in the pictures is what you will be receiving. If you have any questions, or if you would like to purchase one, please send me a PM.
