  • Guests: 39
Want to audio modulate a 555 flyback driver.
Tue Feb 26 2008, 07:05PM Print
I know i can simply do this by hooking a transistor to the power supply to do it but someone else on this forum said something about using pin 5 of the 555.How would this be done?
teslacoolguy
Tue Feb 26 2008, 07:31PM
all you have to do is connect a small amplifier 1 watt to pin 5 on your 555 and the ground to ground on your 555 and it will audio mod.
Wed Feb 27 2008, 04:01AM
Omg thank you so much!I really appreciate that you helped me.Any time i can help you i will!
teravolt
Wed Feb 27 2008, 05:01AM
if you look up the national data sheet for the 555 it shows how to use pin 5 as a pwm. also look up a wabbler oscillator
