  • Guests: 63
First SSTC questions
FireBird
Mon Feb 25 2008, 12:04AM Print
FireBird Registered Member #1104 Joined: Tue Nov 06 2007, 07:38PM
I have been looking into making my first SSTC for a while now and have been wondering a few things.
1) Is Steves Mini SSTC Link2 a good first time project?
2) Is it possible to audio mod this and if so how would it be done?
3) How long and how far away from the coil would the antenna need to be?
4) How many volts would C7&8 need to be?
Thanks for any help.
Mon Feb 25 2008, 01:05AM
1) Yes, I have built it and got it working. (After a while, but that is me not the circuit mistrust .)
2) Yes trough the enable pins on the UCC's.
3) Few inches should do, depends on the spark length you don't want it too close either.
4) About 400v would not go below that, the more the better as long as your caps have a low ESL.
FireBird
Mon Feb 25 2008, 11:44PM
Thank you for the fast response. I will probably make this as my first SSTC then. Hopefully it will work out for me.
