  • Guests: 63
Low Voltage, High Current mosfets on TC?
MRacerxdl
Thu Feb 21 2008, 05:57PM Print
I was thinking if I can make a low voltage tesla coil (24VDC) with MTP53N05 Mosfets (I think its 53A 50V), I was have some troubles with 12V tesla coils, that I didnt get any spark output. Its possible to make a low voltage sstc? (The classical one not the, complex skori one tongue )
Fri Feb 22 2008, 07:52AM
Try the Mazzilli driver, Vasili and others have made SSTCs based on it before.
flannelhead
Fri Feb 22 2008, 01:51PM
PLL is just the way to go. I used 74HC4046 PLL with a single IRFP240 at 12V and it worked just FINE! The frequency was somewhere between 2-2.5 MHz.
You should have at least somewhat 300 turns on your secondary, for a primary I think 3-6 turns will do.
Class E is also good, and especially with your low voltage FETs you should try it. That means you simply put a resonant capacitor across the FET.
Good luck, and feel free to ask help from me smile
MRacerxdl
Sat Feb 23 2008, 01:04AM
The ressoant cap I can calc as the same way that I calc SGTC ressoant frequency (Pcap * Pind = Scap * Sind)?
GeordieBoy
Sat Feb 23 2008, 01:34AM
Class E is a technique developed to minimise capacitive turn-on losses in high-frequency switching circuits using high-voltage semiconductors. As such it gives comparatively little benefit when applied to low-voltage high-current devices.
MRacerxdl
Sun Feb 24 2008, 10:46PM
I will try to make one sometime. Now I need to focus in my Full Bridge :D
