  • Guests: 53
need ucc37322
Mon Feb 18 2008, 03:52AM Print
i am building steve wards class e sstc.were can i find a ucc37322?i only got a few bucks because im only 14!any help will be greatly appreciated!
i also need 1n34a
[Edit: Double posting is bad]
Coronafix
Mon Feb 18 2008, 03:56AM
Depending where you are in the world depends on the availability.
I believe the TC4421 & TC4422 are easily exchangeable.
MRacerxdl
Mon Feb 18 2008, 07:42PM
I used TC4420 and TC4429, its has less current capabilty, but its cheaper (enough for sstc's)
The 1n34a has I know its the diodes that are on the Antenna (Clamp Diodes). You can use 1n4148, its cheap, and common to find it.
