  • Guests: 66
01/13 si2030 (62)
Milling machine chatter ? ?
Sun Feb 17 2008, 08:27PM Print
Just got a small milling machine for building some prototype parts.
Not having any experience in this subject, can anyone describe what chatter sounds like?
Thanks
Dan
Sun Feb 17 2008, 08:45PM
This video has a sample of chatter in it. Link2
Capper
Sun Feb 17 2008, 09:24PM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
Chatter may or may not make a noise. Chatter is a term used for describing a wavy surface formed from your cutting tool. The cause of chatter may be machine vibration, tool speed, tool feed rate, cutting lubricant or coolant type, temperature, or lack of such.
Here's a link to some good info:
link
There are several good forums for home machinists.
link
These guys put out some good magazines:
Home Shop Machinist
What kind of machine did you get? Post some pictures.
Capper
Andyman
Fri Feb 22 2008, 01:20AM
Like Capper said, chatter doesn't always make a noise. Chatter often occurs with a negative rake tool on a hard material without lubrication. You can see the result of chatter in the chip formation. The chips will not be nice and curly and continuous. They'll be discontinuous, rough, and uneven. Of course with a brittle material like brass, all of the chips will be discontinuous, but that's not necessarily a sign of chatter.
Hazmatt_(The Underdog)
Fri Feb 22 2008, 03:38AM
Do you have any pics of your mill?
Can you post some specs. too? I'm going to have to get something to replace my dad's press which he's stealing back. I had an xy table on it, but I'm going to upgrade to a mill as soon as my paychecks start coming in.
Thanks,
Matt
