  • Guests: 58
Alternative to NST?
Ultra7
Tue Feb 12 2008, 09:41PM Print
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
I have heard of using OBIT's (Oil burner Ignition Transformers) for the powering of TC's in the past. Now I think I may have come across a source of inexpensive high voltage OBIT's.
Has anyone on the forum used OBIT's before, and if so, which are the ones to stay away from?
Why I ask, is that as inexpensive as these little guys are, why don't we see more of them in construction of the TC's.
Here is one I was looking at.
Here is the page with spec sheets.
Thanks,
Ultra7
Tue Feb 12 2008, 11:29PM
I suspect that those OBITs are the electronic type, lighter and cheaper than the type that you need - a simple transformer.
If you do find a non-electronic OBIT then you can make quite a nice and reliable SGTC.
(more durable than an NST in SGTC use, but lower power.
