  • Guests: 53
Variac
Alexandre
Fri Feb 08 2008, 12:13AM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
hi all:
There something I can use in place of a variac without suffering interference of the coil?
I tried to use a dimmer, but when they start the coil, Stopped work. mad
Someone has a solution? neutral
Fri Feb 08 2008, 01:14AM
If its a DRSSTC, you can use the pulsewidth to vary output power. However, you'll most likely need an inrush limiter as well so you don't bang on the caps too hard when they charge up for the first time.
Alexandre
Fri Feb 08 2008, 01:30AM
this circuit serves to a simple SSTC?
Shaun
Fri Feb 08 2008, 03:07AM
Steve Connor has a nice circuit for a solid-state variac. I have not built it myself but have heard only good things. His site is scopeboy.com, but appears to be down right now.
Ultra7
Fri Feb 08 2008, 05:20AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Variac is cheap,60 bux at my local electronics shop.
I know that 60 bux might seem expensive to some, but hey, we have one of the more expensive hobbies.
$100.00 for caps.
$100.00 for NST.
$60.00 for a variac.
Coil not on fire, priceless. . . .
Alexandre
Fri Feb 08 2008, 04:09PM
ok thanks cheesey
Hazmatt_(The Underdog)
Fri Feb 08 2008, 08:58PM
Always check the local university. They're always throwing stuff out! Especially the 50 year old stuff that is built to last forever. See if you can befriend the major people who do repairs for the labs, help build power supplies for demos like flyback supplies for Crooke's tubes or discharge tubes (That's how I got my foot in the door) and you're off and running!
You'd be surprised. They throw away vacuum pumps because for 50% more they can buy a new one rather then rebuilding. They throw away power supplies because a cap is dead and its blowing fuses. All that kind of thing that we know how to fix. So give that a shot if you can, its totally worth it.
Alexandre
Sat Feb 09 2008, 05:10AM
I found this circuit on the Internet, and I found interesting, is a variac electronic, uses a SCR, but the way that there is for DC, I modify it to be either as AC DC.
Any suggestions?
1202533813 1228 FT38695 Variac3
CT2
Mon Feb 11 2008, 12:37AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
Th
This is the schematic I was going to use for my tesla coil, ignor the bridge rectifier if you want AC out. I never got around to making it yet, so I can't say how well it works but others have made it, its from some TI application notes IIRC.
Alexandre
Mon Feb 11 2008, 01:49AM
wink
hmmmmmmm
