  • Guests: 37
how we all started coiling? Add your story
teslacoolguy
Wed Feb 06 2008, 04:55AM Print
i thought it would be interesting to see how other people first got started in coiling and building big loud dangerous spark making machines cheesey. I was inspired from my uncle who also built a coil when he was 14 and when he showed it to me it inspired me so much i did alot of research and now i have 4 flyback drivers including a zvs 2 sstc's, 3 sgtc's and i am working on a very small half bridge drsstc and a very large sgtc. I also am learning how to program PIC micros in basic and c. actually i might be wrong but i think being only 14 i am the youngest coiler PS. being homeschooled does help alot shades
Wed Feb 06 2008, 05:18AM
there have been several threads about this in the past... Link2 Link2 come to mind
In any case, my first coil was a 3cc syringe wound with about 200 turns of #30 wire, with a 4 turn helical primary and a small mmc of little ceramic caps powered with the hv source out of a plasma globe rectified by a long string of uf4007 diodes. Made streamers about 1/2" long off 20w in amazed
but I built it back before I had a camera sad
Wirenut
Wed Feb 06 2008, 10:30AM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
The first Tesla coil i ever saw was the one at the Griffith Park Observatory. Link2
I was only about 10 years old, and I was amazed by it. About ten years later, I went back to the observatory for a laser show. I saw the coil again and I knew I wanted to build one. I had no knowledge of electricity at all, and the extremely simple Tesla coil schematic was utterly indecipherable to me. I decided to learn all I could about it, and I started reading up on Tesla. I read every book in the library about Tesla (Wizard was my fave) but none of it helped me figure out how to build a coil of my own.
After a few years of reading everything I could find on the internet (this was 8 years ago) and having it on the back burner of my mind, I finally understood enough to try to build one. My first coil was incredibly ugly. It was wound on a 3" dia. cardboard core of a roll of plastic sheeting with wire that was salvaged from a fluorescent lamp ballast. The ballast was potted in asphalt and the entire coil had black sticky asphalt residue all over it. The primary was wound ribbon style from insulated two-conductor 12ga outdoor "Malibu Light" wire. The wire was wound in a spiral on its edge with no spacing between turns on a piece of pegboard with fishing line holding the wire down. Tapping was done with a nail hammered through both conductors. I made the cap from PE painters drop cloth and al foil, and powered it with 2 mots. Sparkgap was two bolts in a piece of PVC pipe and a mini vacuum cleaner. Topload was two metal salad bowls. I got about 16" out of it and I was hooked.
I love showing my coils to people who have never seen or even heard of one before. They are so utterly amazed. Most people have never seen anything like a deafening four foot electrical arc only a few feet away. I wish I could say something like "And I love educating people about Tesla and the science behind how the coil works" but most people don't care AT ALL. They are just happy to watch a show, and don't want to hear about resonant frequencies or the invention of the induction motor. Showing off something that amazes people never seems to get old though.
guich
Wed Feb 06 2008, 11:11AM
guich Registered Member #1269 Joined: Sat Jan 26 2008, 06:22PM
I was 13 when i built my first TC (sgtc). My brother told me that he saw a tc at school, I was so interested in it, so i also wanted to build one. Now I´m 14 so you´re not the youngest one teslacoolguy tongue
teslacoolguy
Wed Feb 06 2008, 01:24PM
well when i was 13 i built Link2 but that just inspired me more but i did not have a coil working until i was 14 so yes you were the youngest coiler
teslacoolguy
Wed Feb 06 2008, 04:39PM
... wrote ...
my first coil was wound with tv yoke wire i think 26 awg on a 2" pvc pipe and a flyback to drive it i never got to good results so i did more research and wound another coil and now it workes quite well
CompWiz
Wed Feb 06 2008, 04:59PM
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
I was searching Google for Van de Graff generators,
and there was a tesla coil on one site.
I wanted to build one but all the warnings about hv caps scared me(and mom said NO!).
So i just played with a portable CRT TV tried to make a Jacobs ladder(it didn't work, there was not enough power from that little tv).
Then I found a 14" computer monitor but its flyback had a built in cap, but I learned to use a insulated screwdriver to make sparks...
This was almost 3 years ago and I didn't start playing with hv until last year when noticed just how simple the single transistor flyback driver really is.
It did not take me long to get bored of the weak sparks it made(it made a better space heater...).
The fun started when I found the ZVS driver and learned to NEVER touch high voltage!
I built a small tesla coil 3 days ago, it made about 2cm of corona (i don't think the cap was big enough).
I just built a party cup cap and I am going to try that,
but I don't think it will last long (it flashes with corona when it charges).
guich
Wed Feb 06 2008, 05:31PM
i wound my first sec with a the sec of a mot amazed
teslacoolguy
Wed Feb 06 2008, 07:21PM
CompWiz wrote ...
try submerging the party cup cap in motor or mineral oil either should work and that should solve all your corona problems
Wed Feb 06 2008, 07:52PM
guich wrote ...
I'll take your MOT and raise you a clock motor. That worked pretty well on the third attempt at 2am wink
1300+ turns on a 6" former. Yes that worked, though I nearly got stunned painfully by my annoying parents "What the hell are you doing out in the shed at this time ??!!!!!!" lol
-A
btw i thoroughly recommend the use of a winding jig, preferably automated. It sucks winding this many turns manually.
