  • Guests: 59
Parelleling MOSFETs
Coronafix
Tue Feb 05 2008, 08:13AM Print
Just wondering if anyone has tried paralleling MOSFETs for more current carrying capability in SSTC use?
And if not then the reasons why it isn't a good idea.
Being relatively cheap compared to IGBTs ( for some sad ), I imagine it would be a cost effective way of
beefing up an SSTC or even making DRSSTC with this method.
GeordieBoy
Tue Feb 05 2008, 11:59AM
http://www.irf.com/technical-info/appnotes/an-941.pdf
http://www.microsemi.com/micnotes/APT0402.pdf
http://www.fairchildsemi.com/an/AN/AN-7512.pdf
http://www.irf.com/technical-info/appnotes/para.pdf
To summarise the main issues:
1. Steady-state current sharing
2. Dynamic current sharing
3. Parasitic oscillation
4. Providing sufficient gate drive
(In linear applications thermal runaway also becomes a concern.)
Only parallel connect devices of the same type, manufacturer and batch, mount close-together on the same heatsink, keep layout symmetrical and use seperate gate resistors, don't parallel directly at device terminals like in that sketch.
-Richie,
Hazmatt_(The Underdog)
Tue Feb 05 2008, 06:45PM
I've had success with slow speed switching of high current half wave power, but that requires additional design work. My boss needed a half wave switch designed for load switching of Anodize power supplies that was good for single phase or 3-phase half wave where you can't interrupt the power.
I think it would fail quickly for switching faster then a few kilohertz or maybe tens of kilohertz. The heating in the die is your major concern, aka how they share the current.
Dr. Drone
Tue Feb 05 2008, 07:40PM
shades
Marko
Tue Feb 05 2008, 07:50PM
GeordieBoy wrote ...
-Richie,
I just used two paralleled fullbridges for SSTC like Christopher m. ... was that really just a pointless overkill and waste of resources? I thought for a while whether I should just parallel the devices or use split primary...
Coronafix
Tue Feb 05 2008, 10:31PM
Thanks Richie, I was looking for that irf article yesterday but the page wasn't coming up.
I thought of some of your points when I first posted, namely current sharing and gate drive,
and thought that with the mosfet drivers around today it should have enough current to drive them all.
Current sharing would need a very precise topology as you stated, mounting close together and such,
the gate resistors would also need to be closely matched in resistance, small deviations would cause
differences in gate current and therefore different switch on times? Is that correct to say?
As for parasitic oscillation, this would be a problem only on the gate side? and therefore solved by driving through separate resistors?
Of course all this would be mounted on a massive heatsink and fan cooled.
Chris, Marko, look forward to seeing if the design works.
Let us know how you go Marko.
Just bought 20 from Jamaica as well, we'll see if it gets to Australia before I move.
Movin' to the country, gonna eat a lot of peaches. cheesey
GeordieBoy
Wed Feb 06 2008, 10:39AM
In a bridge leg with paralleled switching devices generous deadtime is wise to allow the slowest device time to fully turn off before the fastest device on the other side begins to turn on. If this is not done you can get conduction overlap between say the last device to turn off at the bottom and the first device to turn on at the top. This causes shoot-through down the bridge leg, albeit only through two devices. Generally turn-off wants to be as fast as possible, and turn-on slightly slower but its all in those papers.
If you want to parallel complete H-bridge sub-assemblies, it is best to add some series inductance between the bridge outputs and the commoning point. This raises the effective output impedance of each bridge and improves dynamic current sharing. This added inductance seen between inverters also limits the rate at which "shoot-between" currents can build if the switching instants of the distributed inverters are not perfectly synchronised. The 3rd schematic down on a white background here shows how this can work for an induction heating application:
http://www.richieburnett.co.uk/indheat.html
When you parallel power semiconductors in high frequency applications it is better to parallel them at a high impedance point rather than directly at the device terminals. The inductors raise the impedance at that point without dissipating any power. In an induction heater or RF amplifier the added inductors simply become part of the matching network. In a SSTC they effectively add to the primary inductance, resulting in an effective drop in coupling factor.
-Richie,
Marko
Wed Feb 13 2008, 05:39PM
The paralleled SSTC bridges thing doesn't seem to work well to me, actually, it is defying all reason.
I'll try to be most clear about what I did and what is happening:
I'm using two fullbridges, sharing same supply. Their outputs are separate and led to two primary coils wound together around the resonator. (no electrical contact at all between bridge outputs, all gate drive is isolated!)
When I used one bridge alone (either of those two) they worked very well.
But if I tried to use them both together they wouldn't work.
Coil wouldn't oscillate, dead silence.
Tried running fullwave rectified and CW; no difference. (the circuit works just fine with fullwave rectified!)
But, what is most amazing, if I just leave both bridges together on the power supply and gate drive, but if I connect only one primary and leave another bridge output floating, it *still* doesn't work! No matter how I changed the CT I could do nothing about it.
How in a world can this another bridge affect the first one from just being connected to same supply? I verified it's gate drive and phase before and it was allright.
There was pretty surely no shootthrough on this bridge.
If I remove the bridge from the power supply - everything works fine!
Later I tried putting a lightbulb on the unused bridge output - the coil worked for few seconds, the bulb lit, and then lost feedback, after that I couldn't it make turn on anymore until I disconnected the second bridge again!
Only after leaving the system to ''rest'' for a while, I could do the ''bulb'' trick again, but only for few seconds! wtf?
I hoped and still hope it's just some stupid mistake, since I've never seen as bizzare SSTC inverter behavior like this.
But I disassembled the bridges like 10-15 times now and pretty much confirmed everything in above post.
The driver schematic needed fixing but I hope it's OK now if anyone wants to see it.
Two pairs of drivers driving a dual-primary GDT, feedback directly from a CT.
I measured the clamped CT output and it produces very good squarewave (very high sinewave voltage clamped to 12V) on it's own even at quite low power levels, so I thought I don't need a schmitt trigger in between.
Marko
1202924359 89 FT38563 Sstc
Wed Feb 13 2008, 07:59PM
it would be awesome to try!use a totem pole with a few 1 amp transistors!
Wed Feb 13 2008, 08:06PM
somewhat like this.would it work?
the mosfets of course can not be the exact same gain and all that,but if one uses more it should heat up.wouldn't that cause more resistance therefor making it draw less current and let the others do more work?i am a beginner so i cant be sure if it would work or not.worth a try?because i have a sstc Link2 with a 555 timer i would love to see if i could get more current into the primary because i get 2 amps peak into it :(
