  • Guests: 58
Solid State Tesla Coil Audio Modulation
MRacerxdl
Mon Feb 04 2008, 05:21AM Print
Hi all, I build my first good sstc (a mini one), that can give 4-7cm sparks. Ok good, I started to plan the Audio Modulation
First I have tested puting the Audio on the 555 Interrupter FM In, it not worked good, I was think that because the 555 In Impedance.
I grab one of my Audio Impedance Match Transformers, same like used in Car Amplifiers (To Match the 2 Ohms impedance to 100k of transistors), and put on the FM. Now its looking good than before, but I get too much noise and lower frequencies get a big sparks, and get out the sound of higher frequencies.
Pic of the spark:
Video from audio modulated tesla coil:
What can I do for better modulation? Modulate direct with the coil frequency (with a PLL)?
Thanks
flannelhead
Mon Feb 04 2008, 01:40PM
PLL is good for audio modulation (see Steve C's PLL driver Link2 )
People have reported of getting very good results with that circuit.
MRacerxdl
Mon Feb 04 2008, 03:16PM
I tryed to mount one of that, but I think it doesnt working (I dont know, how to test it off the tesla coil.) But I will try here to put it.
