  • Guests: 61
Primary Base
H~Tank~V
Wed Jan 30 2008, 02:48PM Print
H~Tank~V Registered Member #1253 Joined: Tue Jan 22 2008, 02:06PM
First off, I apologize to the moderator for being a prick in my last post.
I have axis to some CNC equipment in school, that as far as I know can machine a flat helix into a piece of material. Check out the pic below. Is this a good design? I know that tuning the coil will be rather difficult, but im planning on something for that too.
Teslabase
Wed Jan 30 2008, 04:36PM
Perhaps i'm missing something, but the only way to machine a flat coil in some material is to make the flat coil of that material. Which basically means, your coil will be shorted to whatever you machine it out of.
You could probably machine grooves out of a material (like nylon, PP, other plastic) and then insert tubing for the primary.
H~Tank~V
Wed Jan 30 2008, 04:58PM
Woops sorry, yea I would machine a helical coil in a piece of delrin or nylon, that in turn would hold the copper tube in it.
