  • Guests: 53
6 dollar sstc.
teslaguy
Mon Jan 28 2008, 01:17AM Print
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
Ok, so I was dicking around a couple days ago, and I found a broken guitar effects petal. I stole the op amp chip from it, a tl074, and i found a 555 timer. So i set it up to osscilate at 278?khz and fed that to the op amp, then i set up a feed back antennae going to one of the other 3 op amps in the chip, and then both of those going to a third, after that i set it to drive a mosfet gate, and guess what? It worked. So my question to you guys is why use a mosfet gate driver when you can use a simple op amp, i had the whole thing running on 2 ic's. and i can do 2 inch arcs to ground. Ill post pics and a schematic later.
Mon Jan 28 2008, 01:54AM
Gate drivers can put out a lot more power than a signal op-amp, which is necessary for the large FETs/IGBSs that are used in high power coils.
They are also more resistant to noise, etc.
Glad to hear you got it to wok!
Mon Jan 28 2008, 08:15PM
Under 300kHz you can usually do without a gate driver, but they're real life savers as frequency and gate capacitances increase. Since you're driving a single fet gate, and at only 278kHz the rise/falltime will be small compared to the total period. At 1MHz however the ristime might be an entire period!
ShawnLG
Mon Jan 28 2008, 11:09PM
OP amps are not design to drive MOSFETs. They are linear devices. A comparator would work better, because they are on or off, not in the linear region. comparators can not source much current ether.
