  • Guests: 38
300KV from fly-backs?
Mon Jan 28 2008, 06:11PM
I would suggest building a high-frequency isolation transformer that would have windings to drive the primary of each flyback. You would need a fairly large ferrite, but it should allow you to design it to handle 300kVDC between windings (must be in oil!).
I think, though, that there are easier ways to get 300kV, primarily using a C-W stack.
mikeselectricstuff
Mon Jan 28 2008, 10:03PM
Steve Conner wrote ...
The only way round it is to run each stage from its own battery, and switch them on by prodding with a long insulated stick wink
or use fibre optics for switching. Or compressed air.
However I wouldn't be surprised if the first time the output arcs over it takes out all of internal diodes and/or your driver....
Avalanche
Mon Jan 28 2008, 11:01PM
You can build low Khz optoisolators with several megavolt isolation cheaply by using phototransistors (with visible light filter) and IR 'power' leds, all aimed at the ceiling or at a large metal plate wink
Run all stages with one 'sender'. Might lose a bit of sync between stages, as brightness levels/thresholds vary between stages...but who cares - it's already totally nuts anyway cheesey
Tue Jan 29 2008, 12:02AM
Running the whole stuff from a battery should avoid the attraction of the very HV of the upper secondaries to the primaries, because the primaries are not grounded.
I would like to point out that ground is not a magical point that all electricity would like to jump to it is just a common point that is used frequently. Running from a battery will isolate your flybacks from all other conductive paths (like ground) but it doesn't get rid of arcover issues, the voltage potential from primary to secondary is exactly the same in a grounded system as it is in an ungrounded system.
ramses
Tue Jan 29 2008, 10:30PM
ramses Registered Member #1208 Joined: Thu Jan 03 2008, 05:30PM
maybe hook up all transformers up in series, but with the earthiest lead of the secondary shorted to the core and the primary center tapped to the core... and center-tap the middle winding of the whole stack to earth ground. i like the opticoupouler idea. you could probably modulate laser diodes and point them all at a separate photo transistor for each flyback... that would technically reduce the NEED for oil, but i would submerge it anyway. but if you can't attach leads to the ferrite core, forget it. isolation would be needed, preferably rated for the full 200kv if from the line. good luck
Mates
Tue Jan 29 2008, 11:30PM
Ok guys, the solution seems to be completely undoable for me; driving each fly-back from a separate battery and turning it on by laser... frown
However, I have another idea for the use of my fly-back collection and again any comments on this would be highly appreciated. The biggest problem for me when I wanted to built a CW was to get the HV diodes. What about to use the fly-back secondaries as HV diodes in CW stack. I have quite strong (min100W) 6Khz AC 50KV source made of an ignition coil Link2 and also collection of very robust 60KV (4,5nF) capacitors Link2
So do you thing that CW made of these components is worth to try?
G^3
Wed Jan 30 2008, 01:29AM
G^3 Registered Member #97 Joined: Thu Feb 09 2006, 05:40PM
Well this guy used 4 flybacks in series for 100KV to power a particle accelerator. http://www.ifpan.edu.pl/firststep/aw-works/fsII/alt/altineller.pdf
Tesladownunder
Wed Jan 30 2008, 07:37AM
G^3 wrote ...
I'm not sure he used them in series, but I doubt that he was getting 100kV, Certainly his results don't show much difference between 50, 75 and 100kV. He was only using one driver. I don't believe the 100kV.
I have 40 identical flybacks. It would be nice to make a 1MV flyback supply. The only way that might work is with a cascade of big ferrite isolating transformers under oil. Hey, I have a lot of them and a lot of oil and a lot of wire. Shame I don't have the time.
Maybe I'll make a proof of concept version to run 2 flybacks.
Simpler and faster is just multiple individual supplies run by separate SLA batteries with switching by a nylon line. Phasing doesn't matter with separate drivers for a DC output.
TDU
Kizmo
Wed Jan 30 2008, 11:30AM
Tesladownunder wrote ...
G^3 wrote ...
TDU
That would work but you can use 2 flybacks in series without anything special, just by soldering both HV gnd pins together and connecting them to mains gnd
Wed Jan 30 2008, 11:56AM
Only if they're the old-fashioned AC type and wired 180' out of phase.
