  • Guests: 63
Supersize your Minicoil!
Sat Mar 11 2006, 03:01PM Print
Last night was just playing around with some old high voltage stuff, and decided to SUPERSIZE my minicoil. The following circuit puts a DC bias voltage on the RF ground of the secondary making for a very spectacular output.
During normal operation, the arcs of my 4kV/20mA minicoil appear like that of a 4kV/20mA spark gap coil. But use a grounded stick to pull an arc and you draw an amazingly super loud, high current thick nasty arc. Very cool and powerful demonstration, especially if you can hide the additional circuit under an enclosure and just have the minicoil in view.
DISCLAIMER: This circuit is EXTREMELY DANGEROUS AND ABSOLUTELY LETHAL should you contact the output arc. The schematic is included for informational purposes only!!!
1142089295 15 FT0 Supersize01
Marko
Sat Mar 11 2006, 04:14PM
Interesting 'hack' wink
So you put HVDC at base of secondary so you can fire it when sparks ionise air.
How did you build the 100kV 10nF cap, it seems to be only problematic thing here..?
Sat Mar 11 2006, 04:48PM
The 100kV capacitor i used was a Maxwell 100kV 0.01uF x-ray capacitor i have.
Sat Mar 11 2006, 06:37PM
hehe, reminds me of when I pluged my chichen stick into b+ instead of ground...
Sat Mar 11 2006, 07:16PM
Have to try it....But there are some problems to aquire a 100 kV cap....I will see.
Plasmaniac
Sat Mar 11 2006, 08:45PM
Plasmaniac Registered Member #206 Joined: Sat Feb 18 2006, 03:17PM
I've also tried it something like that some time ago, but I used an AC flyback, which is much safer, and also didn't use a cap etc. I just plugged it in series with the secondary.
EEYORE
Sat Mar 11 2006, 09:34PM
vasil wrote ...
Would seriesing some ceramic disk caps suffice?
Matt
Marko
Sat Mar 11 2006, 10:22PM
Nop, for 50 joules you need kilos of them.
Large collection of pp/pe or worse glass bottles may be a try (and probably you would need to series them).
Or see capacitor made of plastic plates, there is a topic on this forum...
ragnar
Sat Mar 11 2006, 11:03PM
LOL - nice deathtrap, EVR =D
There's a great video of someone this on the TCML somewhere... quite impressive.. good work man cheesey
EEYORE
Sun Mar 12 2006, 08:27AM
Firkragg wrote ...
I dont see why one would need 50Js to see results...I would still be inclined to take some of those 40kv 2200pF ceramics i see pop up on ebay and try it out.
Matt
