  • Guests: 54
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
building my first sgtc
1 2 3 4  last
SilentPhoenix
Wed Jan 23 2008, 02:27PM Print
SilentPhoenix Registered Member #1258 Joined: Wed Jan 23 2008, 11:52AM
hi all,
i'm planning on building a sgtc for a schoolproject and i've did some research and made some calculations but i've ran into a few problems.
i've got two neoncomp NST's:
1201098030 1258 FT0 Nst Specs
and i was wondering if i can put them in parralel to create 8+6.3=14.3kV.
i know that it is possible with most transformers but since mine have two live outputs instead of one i didn't know how to connect them.
is there anyone who has tried this before and can give me some tips? or is it just not possible?
greetz Phoenix
Andrew H
Wed Jan 23 2008, 06:29PM
Andrew H Registered Member #1198 Joined: Sat Dec 29 2007, 05:39AM
You parallel transformers to increase current not voltage. If you want to increase the voltage you need to connect your transformers in series. However, putting NSTs in series is not generally a good idea because you will likely exceed the voltage rating of the secondary and burn out your transformers.
Just using the 8kV NST should be fine for a small demo coil anyway.
Ultra7
Wed Jan 23 2008, 07:20PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Go here for a good read on NST's.
NST
Logan Kennedy
Wed Jan 23 2008, 08:14PM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
If this is for a school project I would be very weary about buliding something even moderately large. I would forget the idea of using NST as they are too large and bulky for this specific application.
Choose something like a small flyback power supply using the ZVS driver. This topology should provide you with more than enough energy to run and demonstrate a tesla coil for a school project.
Ultra7, you live in Houston too? How strange! Do you ever visit EPO?
Ultra7
Wed Jan 23 2008, 08:58PM
Logan Kennedy wrote ...
Man, I practically live there.
EPO is one of my favorite places to spend a Saturday afternoon and half a paycheck.
Wed Jan 23 2008, 09:16PM
Are you sure they aren't switch mode neon sign transformers.
SilentPhoenix
Thu Jan 24 2008, 11:27AM
@ dalus: what is the difference between a switched mode and a regular nst?
the ones i have are the ones this guy Link2 refers to on the 05:40 mark as "m-point" transformers.
@ ultra7:
so what you're saying in the link you gave me is that i can put them in parallel but i would have to find the right phases by trial and error? wouldn't it be a problem that they have different voltage ratings?
if i put them in parallel that should give like:
(6300+8000)/2 = 7150V @ 2*50=100mA right?
would doubling the amperage improve the functioning of my coil?
btw i have recently built a jacob's ladder because i had these transformers laying around and i couldn't wait to test them :P i'm kind of looking around to see if there's any fun stuff i can do with a jacobs ladder. i saw pics of a guy who built one in a glass tube and filed it with lightergas but that's too dangerous for me :P i was more thinking about creating different colours of spark or something.
i also built a bottle capacitor from 3 glass 30cL beerbottles, some saltwater and some alufoil. i tested it and it worked quite allright but i have to get a better multimeter somewhere to measure the capacitance. is there a formula to calculate capacitance based on input voltage/amperage and dielectric?
greetz
Ultra7
Thu Jan 24 2008, 07:10PM
SilentPhoenix wrote ...
@ ultra7:
greetz
Exactly!!!
More current = Bigger sparx!
Do you have Teslamap yet?
If not it's a free download at Link2, and you can play with all your numbers on it and see what differet current/voltage values will do to your output. Also it will give you accurate tuning points, LTR Cap values. . . you get the drift.
Oh, and I was just like you when I got the NST, I built about 3 Jacobs ladders' and did all kinds of arc and spark experiments. I could not contain my desire to build my coil. When all my parts were together and I began final construction, it was like the buildup to that final date with the woman of your dreams and she orders the lobster dinner.
Logan Kennedy
Thu Jan 24 2008, 10:23PM
wrote ...
I wouldn't say this is always true. Input voltage also plays a big role in spark evolution and length. Generally speaking, more current only intensifies arcs.
Ultra7
Fri Jan 25 2008, 04:53PM
Ahhh, but notice I didn't say LONGER sparks, just bigger sparks.
1 2 3 4  last
