  • Guests: 59
homemade toroid - need help
bluemotion
Wed Jan 23 2008, 11:09AM Print
bluemotion Registered Member #1200 Joined: Mon Dec 31 2007, 01:43PM
OK. I have finished the former. I just curious what kind of store did you guys get the Al tape. I can only found Cu tape in local component store. I did found some Al tapes for decoration, but they are only single layer conductive.
Center is Acrylics covered by Al foil.
Bluemotion
1201086561 1200 FT0 Dcp 3095
Wed Jan 23 2008, 12:39PM
Wow, cool looking toroid.
Not sure about Taiwan, but here in the US, aluminum tape is found in most home improvement stores or hardware stores. It should be in the heating section. If you can't find it there, check your local heating supplier.
Marko
Wed Jan 23 2008, 01:45PM
Opposite, copper tape just doesn't exist here, and I needed it so many times, and have Al tape all around (although even it isn't to easy to find here)
What do you mean by ''single layer conductive''? Adhesive is poor conductor and will provoke arcing if firm electrical connection isn't good, but it should not be a too big problem for a toroid.
Or you have that paper-sided Al foil tape, or something similar?
bluemotion
Thu Jan 24 2008, 12:23AM
@EastVoltResearch
Thanks, I will check it out in the next few days.
@Marko
I mean one layer of it is double sided adhesive tape, I guess that's what you mention(paper-sided Al foil tape).
