  • Guests: 56
Wood for Primary Supports
Wed Jan 23 2008, 03:05AM Print
Just curious how many of you have used wood for primary supports.
Let me know your experiences.
I personally never use wood, and never will for my own coils, but i have a few demonstration coils i need to have some students build, and by using wood
makes things much much simpler for them. If it can hold up a few runs, thats all that matters.
Wirenut
Wed Jan 23 2008, 03:09AM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
The primary supports on my miniBrute replica are wood. No problems (yet?) so far with about 10 - 15 min total run-time.
Shaun
Wed Jan 23 2008, 03:59AM
My first TC had wooden primary supports; just 3/8" plywood. Being an HV noob, I didn't bother to varnish it. It arced to the secondary a few times, developed a carbon track, and that was the end of it. Now I use chopped up cutting boards.
Tom540
Wed Jan 23 2008, 04:22AM
Tom540 Banned on 3/17/2009.
Ive tried wood and it was a pain if you try and drill holes to seat the turns in. The wood falls apart when drilling the holes, you cant put the turns to close together. I suppose if it was a really hard wood it might work better.
Coronafix
Wed Jan 23 2008, 05:26AM
I'd say it all depends on the type of wood used.
Using soft wood or glue impregnated wood like chipoard or
ply wouldn't be too good. I think a nice dry hardwood would be good.
Or I'm not Edward Woodward!
Dr. Slack
Wed Jan 23 2008, 08:04AM
There's an OMG magnifier somewhere which uses varnished kiln-dried Sitka Spruce for the primary/secondary pair, though I don't recall what it uses for the magnifier coil.
Mates
Wed Jan 23 2008, 08:38AM
My guess is that first Nicola Tesla's coils were made of wood. At least I've seen some of his replicas made of wood. I would use definitely some good epoxy or acrylate coating...
