  • Guests: 59
Seconday number of turns.
H~Tank~V
Tue Jan 22 2008, 02:11PM Print
H~Tank~V Registered Member #1253 Joined: Tue Jan 22 2008, 02:06PM
Hi,
I started building a coil a few years back. All I ended up doing was winding the secondary coil. So now its been 3 years or so and I forgot how many turns are on the primary! I really dont want to count each turn by turn, but if it comes down to it I will.
I was thinking that I could find the resistance of a 1' piece, then take the resistance of the primary and divide by the resistance of the 1'piece, which would give me the length if the wire. Then I would take that and divide by the circumference of the pipe its on.
Thats all fine and dandy, but I dont think my meter will be very accurate, its just a hand held fluke multimeter.
Help!
Andrew
Mates
Tue Jan 22 2008, 02:19PM
H~Tank~V wrote ...
Hi,
Help!
Andrew
Divide the hight of your coil by the thickness of your wire. That's far more accurate than resistance measurements unless you have some super hi-tech ohm-meter...
BTW: There is no need to know the number of turns exactly.
You also mass primary and secondary! mistrust
Wirenut
Tue Jan 22 2008, 07:22PM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
As Mates mentioned, if you know the wire gauge, you should be able to calculate it with a chart such as the one here:
Another thing I've done before is simply count the number of turns in one inch and multiply by the length of the coil.
Zum Beispiel
Tue Jan 22 2008, 07:43PM
Flukes are pretty accurate...
But the amount of turns is not that important. The frequency will be +/- 50kHz anyway depending on where the coil is located.
H~Tank~V
Tue Jan 22 2008, 10:19PM
Ok, cool. I thought the number of turns had to be pretty accurate. So il just divide the length by the diameter of the wire.
Thanks!
