  • Guests: 75
Jackpot or another POS to clutter my room?
Ruyck
Tue Jan 22 2008, 02:14AM Print
Ruyck Registered Member #1195 Joined: Thu Dec 27 2007, 02:31AM
Hi all, I received a "Cenco High Voltage Source" today. What exactly have I stumbled upon? And is it tesla coil compatable? The input is 115V 50-60 cycles 25 Amp. Output is "1/2 to 1 1/2 inch pulsating DC spark." Thats what it says right on the unit. When plugged in it creates about 10 hz pulsing arcs across the two connectors at the top of the unit. Very Loud.
1200967644 1195 FT0 0121081831a
1200967644 1195 FT0 0121081831b
1200967644 1195 FT0 0121081840a
The bottom picture is what I see when I open the bottom of the unit. It seems like there are two small coils, 3 AC caps, and underneath the circuit board (in the wooden part of the case) there is a large transformer.
The thing that I'm not so sure on is the "DC" aspect and the slow frequency. The Unit does not give any more information on the output other than arc length.
Let me know what you think. Or if you'd like some more info.
Tue Jan 22 2008, 03:15AM
Thats most likely 25mA, not 25A or maybe even 0.25A.
Shaun
Tue Jan 22 2008, 03:51AM
Well, in the first pic I can see its labeled "Solid-State Induction Coil." Plus, I think I can also make out a single power semiconductor in pic #3, just above the right coil. My guess would be that its a nicely boxed iggy coil driver, but without an "iggy coil" per se.
Ruyck
Tue Jan 22 2008, 06:50AM
Not to sound...ignorant... but whats an iggy coil? And any ideas what I could do with this thing? I have an almost built tesla coil (minus appropriately sized caps and a NST...it popped). I was hoping this thing could replace my NST. Any chance of that happening? I'm still not really sure what I've got here.
And it really does say "115V 50 60 CYCLE 25 AMP."
Tue Jan 22 2008, 07:04AM
You can't power a tesla coil off this thing. For starters it is too low power, not more than a few watts. Second, the output is pulses of very high voltage (30-50kv methinks) high frequency ac, which would be almost impossible to rectify to charge a tesla coil with it.
But that doesn't mean it is useless, there are all kinds of fun ways to play with a 50kv pulse transformer wink
Bjørn
Tue Jan 22 2008, 07:18AM
Iggy coil is slang for ignition coil
Tue Jan 22 2008, 11:37AM
i believe these are great for illuminating gaseous tubes though.
Shaun
Tue Jan 22 2008, 11:40PM
Somehow I doubt this thing even approaches the specified 2,875 VA. If it was pulsing at 10Hz, that would be 287.5 J per bang. That would be deafening, not just very loud. Or maybe its just horribly inefficient.
Plus, chances are you have a 20A breaker which would blow at 25A. And if not, the power cord would be VERY warm, if not hot to the touch.
This does not look like it would be usable for a tesla coil, but I'm sure there are tons of other fun uses for it.
