  • Guests: 48
This weekend project
KresoLiubov
Sat Jan 19 2008, 08:31PM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
Stay tuned :) ...
Because i consider that sparklenght is too small for fullbridge. Any suggestions?
1200774683 1153 FT0 Dsc01493
1200774683 1153 FT0 Dsc01494
1200774683 1153 FT0 Dsc01495
1200774683 1153 FT0 Dsc01496
1200774683 1153 FT0 Dsc01497
Zum Beispiel
Sat Jan 19 2008, 09:43PM
I assume this is with full wave and smoothed input? That + low coupling = short sparks.
Try using less primary turns and try to spreading them out more so they cover a larger part of the secondary.
For longer sparks half wave input helps a lot. Either that, or use an interrupter.
KresoLiubov
Sat Jan 19 2008, 09:46PM
Zb wrote ...
Yes its fullwave smothed input. Unfortunately there is verry little heatsinks so i cant use greater power levels. Coil is intrupted. Interupter taken from here :
Capacitor is 0.1 uF
Resistor is 1 Kohm
