  • Guests: 69
Improved single transistor flyback driver
1 2 3 4  last
Sat Jan 19 2008, 04:10PM Print
This could be interesting for the HV newbies that want to build their first flyback driver (maybe it can even be "implemented" in the Hv Wiki?)
I wanted a quick&dirty HV power supply for some lightbulb plasma experiments so I threw together the single transistor flyback driver. I played with it a bit and here's the result of my experimenting:
1249482235 152 FT37658 Stfd2
The 0.47uF cap should be a high-quality foil or film one. The value is not critical , my circuit starts to work well from 0.22uF.
The transistor gets warm but not as hot as with the original driver, but mainly the arcs are 3x as big and hot. The output voltage is also a bit higher.
I used an old transistor by "Tesla" (KD606), I think it should work just as well with 2N3055 or similar. (Note: a HOT or any other higher voltage transistor will not work, because they have different internal structure and the circuit will fail to oscillate)
Video here:]1200758621_152_FT0_pict0289.wmv[/file]
It is still not "fine tuned", maybe other people could try it and experiment with number of turns etc and post what works best for them?
HvHaxor05
Sat Jan 19 2008, 07:05PM
HvHaxor05 Registered Member #1116 Joined: Tue Nov 13 2007, 02:11AM
WOW i am impressed i will be sure to make this circuit and try it out my self ty
Firnagzen
Sun Jan 20 2008, 01:23AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
I'll point out that since this circuit depends on the transistor being saturated to switch, the lower the saturatin voltage, the better. The MJE13007/8/9 transistors are fantastic for this.
MRacerxdl
Sun Jan 20 2008, 02:56AM
Very impressive arcs :D I will try some time the driver with a MJE13007 that are High Speed Transistor (up to 100Mhz if I am't mistake)
Sun Jan 20 2008, 08:39AM
Firnagzen wrote ...
I don't know if they will work, they are 400V transistors.. Something is wrong with the HV transistors, they have much higher Toff time and lower Hfe (I was trying to find out the difference and I believe it was in how the base was made - epitaxial vs. triple diffused IIRC)
The MJ15003 is a nice transistor for this circuit
flannelhead
Sun Jan 20 2008, 12:52PM
It looks a bit dangerous... Isn't it too dangerous to recommend to a beginner?
However, very nice arcs from such a simple circuit!! smile
Zum Beispiel
Sun Jan 20 2008, 03:35PM
That is *very* impressive amazed
I would expect to see such arcs from a halfbridge or fullbridge, but certainly not from a single transistor! I'll have to try this some time.
flannelhead
Mon Jan 21 2008, 02:08PM
I was wondering could this kind of circuit work for an sstc? Here is something similar: Link2
Some beginners would really like it...
Mon Jan 21 2008, 03:24PM
spark wrote ...
I don't know, since this circuit relies on the saturation of the ferrite core... Maybe it would work but the capacitor would need to be adjusted or removed completely. For single transistor SSTC see Link2
DuartmaN
Wed Jan 23 2008, 12:20PM
DuartmaN Registered Member #1257 Joined: Wed Jan 23 2008, 08:59AM
Amazing! i can use this HV generator to excite a tesla coil? congratulations for this forum im from portugal, and in my contry dont´t existe foruns abaut tesla coil and electronics either.
When i 14 yrs i contruct smal PVC tesla coil with a relé and a iverted 12v 200v transformer! but work´s with a smal spark´s, now i wold like to contruct a biger tesla coil but i need a HV generator, maybe contructed with a flybak T like thise on thius topic!
*sory my englis
1 2 3 4  last
